opinions on chevron delo 400
Old 03-06-2014, 04:53 PM
23larry24's Avatar
23larry24
23larry24 is offline
23larry24 is starting off with a positive reputation.
What do you all think of chevron delo 400? Anybody running it? Walmart has it for $10 a gallon.
Old 03-06-2014, 04:56 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.
I run it! It seems to quiet my engine. Winter time I get the romps though.
Old 03-06-2014, 05:00 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
One of the great 15-40W oils out there and $10 per gallon is a buy! When I used my truck a lot I always used Delo 400. Now that I hardly drive it, I just change oil once a year and go with 5-40W synthetic. We use to run the Delo 400 in a bunch of heavy trucks and I still use Delo 100 40W in my Detroit 8V92TA. If you live in a warmer winter area of the country that Delo 400 will serve you well.
EDIT: I just saw you are in Michigan...I advise using a 5-40 W diesel synthetic like Rotella-T or Delo 400 synthetic.
Old 03-06-2014, 05:06 PM
23larry24's Avatar
23larry24
I have rotella 10w30 in now but am looking for a good deal on summer oil.
Old 03-06-2014, 05:20 PM
nlemerise's Avatar
nlemerise
That Delo 400 will serve you well in the summer...stock up at that price. I pay $13/gallon for the 40W Delo 100 .
Old 03-06-2014, 06:46 PM
binuya's Avatar
binuya
binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
My best Blackstone OA's have been when I have used Delo 400. Strong additive package that remained strong to the end of use, and my wear metals were always well below average. If it weren't for those annoying romps, I'd be running it year round.
Old 03-06-2014, 08:51 PM
Lying Larry
Lying Larry is offline
Lying Larry is starting off with a positive reputation.
My 01 7.3 has never seen anything else. Still runs good at 195 K. I use it in most other things I own also. I hope our Wall Mart has it for that price
Old 03-07-2014, 12:31 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
here here...run'n the syn delo now for another 2500 miles, then in goes the delo 15/40
Old 03-07-2014, 12:43 AM
cutlass's Avatar
cutlass
cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
I always run Delo 400 when I'm not using synthetic.
Old 03-07-2014, 01:20 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Too old to be too smart
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
I have run dino Delo since I bought this truck, and have run it in some gassers as far back as 1964. Never have had a lubrication-related failure with it.
I still get very good Blackstone reports, and I run it out to 15,000 miles using bypass filtration.
Maybe that's not for you (YMMV admonition), but Delo and Baldwin filters have served me well for about fifty years.
Pop
Old 03-07-2014, 11:30 AM
lhud
lhud is offline
lhud has a good reputation on FTE.lhud has a good reputation on FTE.
Pop
Great to hear this from you Pop. I have the oil by-pass filter but never thought of extending the mileage on my oil change with dino oil. With synthetics I will go to 10k and 12k on an oil change. I've always wanted to use dino in the summer and syn in the winter - I'm gonna give this a go.
Thanks Pop for sharing,
Old 03-09-2014, 09:29 AM
Studawg's Avatar
Studawg
Studawg is offline
Thread Ender
Studawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to all
Pretty sure its also the factory fill oil for the old I5 Merc diesels. Just did an oil change on an 1985 300DT and found that if you order oil for it from the dealer, thats what you get. (I purchased from Wal-Mart, of course. )
Old 03-09-2014, 02:12 PM
binuya's Avatar
binuya
binuya is offline
Mercedes also used it in in their gassers up into the mid 90's.
Old 03-10-2014, 09:53 PM
Dave7.3's Avatar
Dave7.3
Dave7.3 is offline
Dave7.3 is gaining momentum as a positive member of FTE.
Is that the T5 semi-synthetic? Do a search and you will find some exceptional oil analysis reports, especially from the 6.0L guys. I just made the switch to the T5 stuff, I figure if it can stand up to the beating from a 6.0L year round, it should be more than enough for my 7.3L!
Old 03-11-2014, 06:44 PM
23larry24's Avatar
23larry24
Ya, its the t-5 semi-synthetic. You run it year round?
Quick Reply: opinions on chevron delo 400
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
