Transfer Case Full of Fluid
Old 03-12-2014, 06:54 PM
ChrisMelton78's Avatar
ChrisMelton78
ChrisMelton78 is offline
Hello everyone! I have a 1990 F250 4x4 with E4OD. I haven't had the truck very long, but I just realized that 4x4 didn't work. I narrowed it down to the transfer case. When I pulled the old transfer case off it was really, really full of fluid. I would estimate several quarts. I didn't pay much attention to it at the time.
So, I sourced another working transfer case. When I bought it I drained all of the fluid out of it and cleaned it up a bit. I installed it on the truck, reconnected all of the drive shafts, and removed the fill and drain plugs in order to prepare refill it. When I removed the drain plug about a half a quart of fluid came out.
Where in the world did this fluid come from???
Old 03-12-2014, 07:03 PM
d-day's Avatar
d-day
d-day is offline
From the trans... input t case seal was probably not good anymore causing fluid to transfer.. that's usually what happens
Old 03-12-2014, 07:27 PM
ChrisMelton78
How does one go about fixing this?
Old 03-12-2014, 08:26 PM
d-day's Avatar
d-day
d-day is offline
A new input seal and a trans gasket, adjust t case fluid accordingly
Old 03-12-2014, 08:28 PM
ChrisMelton78
I see that there's a seal on the transfer case input shaft, but is there a seal on the transmission output shaft that I need to replace as well?
Does anyone have any part numbers by chance?
d-day's Avatar
d-day
d-day is offline
This one
And
Ford used a opened end tail housing, so use the gasket supplied by Ford or your local transmission shop should have one or rtv
Old 03-12-2014, 08:31 PM
ChrisMelton78
Also, when I installed the new transfer case, I just used Ultra Grey RTV instead of a gasket between the transmission and transfer case. Do you see any issues with doing it this way?
Old 03-12-2014, 08:47 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
I used white Tub & Tile silicone. It's been a good year so far, no leaks(from there, anyway <_< )
Old 03-12-2014, 09:05 PM
ChrisMelton78
Really?? That's very interesting!
Old 03-12-2014, 09:08 PM
ChrisMelton78
So, just so that I'm clear, replace just the input seal on the transfer case. There's nothing to be replaced on the transmission output, right?
Old 03-12-2014, 09:13 PM
d-day's Avatar
d-day
d-day is offline
Correct, it is just a open housing on the transmission side, you will see a big ol hole. Clean area and install gasket or rtv and you're good to go
Old 03-12-2014, 09:17 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
RTV is fine, but I prefer the gasket, just my preference though.
I had a hard time finding it local, so I got it here:
Transfer Case to Adapter Gasket 4WD 4 x 4 Ford Borg Warner 1345 1350 1354 1356 | eBay
Old 03-12-2014, 09:19 PM
ChrisMelton78
d-day, you sir, are the man! I appreciate the info. Now I've just gotta get the motivation to take it all back out now.
Old 03-12-2014, 09:26 PM
d-day's Avatar
d-day
d-day is offline
Lol I don't know about being the man haha. Just like to help out a fellow member when I can or if I know how. Drive train I am pretty set on, I am also still new to a IDI
Old 03-12-2014, 09:29 PM
d-day's Avatar
d-day
d-day is offline
On a side note these are probably one of the easiest engines & vehicles to work on.. I am comparing to vehicles today, I work for Chrysler/ dodge and I would have nothing to do with a new $75,000 truck, I would take my old 85 any day
Quick Reply: Transfer Case Full of Fluid
