Im glad this was brought up. Since I have started monitoring mine, I usually stay within 10*traveling at highway speeds,(194 EOT and 185 ECT . During driving around town,they stay within 5-7* with the EOT being in the 188-189 range. Seems pretty good to me, what do you pro's think?
Those temperatures are the same as my Excursion after I changes the oil and egr coolers and it has been installed about 15,000 miles no matter what the outside temperature. The EOT does sometimes get above 220* when the speed is above 80 mph and ECT temp. stay within 13* or lower. The delta also get above 15* for short period of time when going up incline and winding road at speed above 80 mph but cool down within minutes after the road level out.
As I recall, the correct test is the engine at operating temp. ECT at 190* and steady 65 mph for about 10 miles; EOT temp. should be less than 205* (less than 15* difference)
That sounds like a blast! Great way to have fun with the kid(s) also. What kind of speeds/times are you running?
We only run 300ft, if we went asphalt, we would be running 1/8 mile. Mine runs in the 3.9 sec range at around 81mph, my daughters is in the 4.4sec range. Lots of fun and money. Lol. I started her doing it when she was 12yo, she is 22 now.
Originally Posted by VQT
Those temperatures are the same as my Excursion after I changes the oil and egr coolers and it has been installed about 15,000 miles no matter what the outside temperaturep. The EOT does sometimes get above 220* when the speed is above 80 mph and ECT temp. stay within 13* or lower. The delta also get above 15* for short period of time when going up incline and winding road at speed above 80 mph but cool down within minutes after the road level out.
In comparison,to your new coolers and temps, it seems as though mine is fairly healthy, and that makes me and my truck happy. However, I have a new Ford oil cooler that I got for free, so im gonna go ahead and install it when I do the EGR delete and a few other things.
Some of the aftermarket oil coolers have larger-but fewer passages. The idea being it's harder to clog them up but I've read several posts where the EOT runs higher with that design. I looked on the Sinister site (MKM) but really couldn't tell how their's is made.
Either it's one of those designs, or possibly there is still trash in the coolant system and the new cooler is clogging.
So what you're saying is my deltas might be the result of the oil cooler design or it might be plugged again?
I'm also curious if a little bit of oil residue in the coolant could reduce the heat transfer in the oil cooler, even if the cooler isn't plugged?
If the flow is "too" good through the oil cooler, could the EOT be going up? i.e. the oil and the coolant aren't in the cooler long enough to actually cool the oil all the way?
If the coolant flow is too fast through the oil cooler you definitely will not get efficient heat transfer. The IPRresearch "high flow" oil cooler had that problem and if you'll notice, it's no longer available.
Hmmmm...I wonder if I could test that theory with an orifice in the oil cooler coolant out line...has anyone tried that?
What about using another inline cooler like a trans cooler with a temperature controlled fan? Bad idea? Or just too much going on.
Really, two issues at happening in that situation. Coolant flows quicker so less time for heat transfer and there is less surface area if the plates are fewer.
That has crossed my mind.
Since I see the coolant temperature change between the new thermostat and the old thermostat and I see the exact same change with in the oil temperature, I've determined that it is safe to assume that the oil cooler isn't plugged.
Now to determine the most cost effective next step.
So slowing the coolant should improve the heat transfer...
I've tossed around the idea of using an E Series remote filter set-up and then using the EGR cooler as another oil cooler. The exhaust side would become the oil side and then mimic the 7.3 oil cooler setup
Josh
Sounds interesting...except I don't have an EGR cooler on the engine anymore and the one in the box on the shelf in the garage has a hole in it somewhere...I'm keeping it just incase I ever have to plug it and dummy it into the engine in the future.
I would use a brand new unit that has been hot tank and cleansed really well. Also likely use a Bullet Proof style with the larger exhaust passenges for the oil to flow better.
Just need to get my hands on one of those remote filter setups to see how the hardlines are attached etc to figure out the new oil lines will work.
If I were you I would not change the Oil Cooler at this point. I understand the whole "I am already in there" thought, but I think that by messing with stuff and disrupting the cooling system you could cause problems. You could stir up debris in the system and plug the new cooler. If I were in your shoes, I would sit the new cooler on the shelf for when you actually do need it. Lots of folks on here have replaced oil cooler and still only get as good as deltas as you are currently getting. JMHO.
I think that's generally true, except for some diesels. I used to push my GTO through the staging lanes by hand and it was a street car! I tried to launch at 150* or less. It took a full tenth of the 1/8 mile time from 190*. Later in the night (if I was still in the running ) there wasn't enough time to cool off good between rounds even spraying down the radiator, it would slow down a little unless the ambient temps dropped a lot or I "compensated" .
Sorry OP
What year of GTO? I drag race a lot and I am a Huge Pontiac Guy. I am Currently running a 1964 GTO. Just curious about yours. Do you still have it?
