Yet Another EOT/ECT Question
Old Mar 13, 2014 | 04:20 PM
  #31
diggintrenches's Avatar
diggintrenches
Originally Posted by Green96
If I were you I would not change the Oil Cooler at this point. I understand the whole "I am already in there" thought, but I think that by messing with stuff and disrupting the cooling system you could cause problems. You could stir up debris in the system and plug the new cooler. If I were in your shoes, I would sit the new cooler on the shelf for when you actually do need it. Lots of folks on here have replaced oil cooler and still only get as good as deltas as you are currently getting. JMHO.
Hmm, that's definitely something to think about as well.
Old Mar 13, 2014 | 04:37 PM
  #32
npccpartsman's Avatar
npccpartsman
Originally Posted by Splash67
So slowing the coolant should improve the heat transfer...
Personally, without the EGR cooler being in place, I wouldn't worry about the temp delta unless you're getting some really high EOT's. You won't hit a defuel until 254, the standpipe in the oil filter doesn't melt until 350 (read this as NEW MOTOR), and modern oils don't start to break down until higher temps than that.
Old Mar 13, 2014 | 04:44 PM
  #33
diggintrenches
What does the EGR being blocked off do to the temperatures? Any difference at all?
Old Mar 13, 2014 | 04:56 PM
  #34
Green96's Avatar
Green96
The high differences in the oil and water temp signifies that there is a restriction in the coolant system. If you have a working EGR cooler and there is a restriction in the system it can cause the EGR cooler to overheat and rupture. When this happens you can be putting antifreeze into the cylinders, which is a big no-no.
Old Mar 13, 2014 | 07:33 PM
  #35
Splash67's Avatar
Splash67
I tend to agree with you...especially after seeing the EOT go up and down with the change from an old thermostat to a new one.
Besides, if the head gaskets blow, it'll be a good excuse for me to rebuild the top end and push her HP up to 700 or 800!
Old Mar 13, 2014 | 11:11 PM
  #36
diggintrenches
That part I do understand, I was referring to weather or not it raised or lowered either of the two with the EGR being deleted.
Old Mar 14, 2014 | 05:04 AM
  #37
npccpartsman
I'm sure that with the EGR cooler being blocked off it takes some cooling load off the system but I doubt that it's significant. Your motor is getting cleaner air to burn but it's producing more NOx.
Old Mar 14, 2014 | 05:11 AM
  #38
diggintrenches
Thank you sir.
Byrd.Dog
Oct 2, 2017 09:25 PM
johnsparks302
Jul 18, 2017 01:09 PM
ProjectToyHauler
Oct 3, 2016 05:39 PM
gmcbride
Sep 19, 2016 01:39 PM
ZooDad
May 29, 2009 12:58 AM
