C6 transmission question
Old Apr 17, 2014 | 10:09 PM
Ken Blythen's Avatar
Ken Blythen
Originally Posted by bruno2
Does the column have to be changed in order to go from a non OD to an OD tranny?
No, just the indicator face is different........both transmissions have the same number of shifter positions.
But when I swapped from an AOD to a C6, the selector arms on the side of the two transmissions were different lengths; I had to shorten the C6 one to get the correct travel for shifting, & for the dash indicator.
The linkages mount to the trans slightly differently too.
Old May 8, 2014 | 04:38 PM
Daves94vert's Avatar
Daves94vert
found a 302/c6 tranny out of a 92 150. Will this c6 work or do I need an earlier model?
Old May 8, 2014 | 04:45 PM
Gary Lewis's Avatar
Gary Lewis
I think it will work - except it may not have a place for your speedo gear to be inserted. Some place along the way they changed to electronic speedometers and did away with the speedo gear in the tail shaft. But, if that one has the hole for the speedo then it should work.
However, make sure the output shaft is the same as yours since those varied somewhat.
f100today
Dec 1, 2011 09:03 AM
97powerstroke
1978 - 1996 Big Bronco
Sep 3, 2011 06:56 PM
MUSKRATT2
23
Aug 15, 2011 09:01 AM
Nackel
Nov 20, 2007 07:04 PM
trikyriky9
Jun 20, 2006 10:14 PM
