Sponsored by: Real Truck
No Brake Lights
Old Mar 10, 2014 | 09:56 PM
Fordcrazy21's Avatar
Fordcrazy21
No Brake Lights
Bought an 04' F250, looked good but definitely not well maintained. Have replaced tranny temp sensor, thermostat, fuel filters, air filter.... Etc. heads have been redone and new studs installed , Egr delete, new oil cooler, flushed cooling system. Now tonight coming home noticed the brake lights aren't working, all 3 are out... fuses are good. I've heard multifunction switch or brake switch..... If anyone can help it would be appreciated
Thanks
Old Mar 10, 2014 | 10:27 PM
eberlestock's Avatar
eberlestock
I had this happen in 2 company trucks of that year. I don't remember exactly what the problem was but I do recall it was a part that needed to be replaced in the steering column.
Old Mar 11, 2014 | 06:23 AM
Fordcrazy21
As I researched, seemed to look like if it was the multifunction switch in the column the brake light on the back of the cab still worked.
Old Mar 11, 2014 | 07:01 AM
projectSHO89's Avatar
projectSHO89
If the high-mount stop lamp works, it is probably the MFS. [edited.... changed the word 'not' to 'probably' after coffee kicked in]
If all three are out, check the switch on the brake pedal arm and its fuse.
Old Mar 11, 2014 | 09:12 AM
Fordcrazy21
K, thank you
Old Mar 11, 2014 | 12:08 PM
tjc transport's Avatar
tjc transport
i ain't rite
if the high mount brake light is working, the brake pedal mounted switch is working and it is either a blown fuse in the under hood box, or the multifunction switch.
do the rear blinkers and 4 way flashers work? it may be something as simple as bad bulbs.
Old Mar 11, 2014 | 01:26 PM
Fordcrazy21
4 ways and blinkers work, can mount brake light is not working. Fuses are all good
Old Mar 11, 2014 | 02:01 PM
tjc transport
i ain't rite
if blinkers and 4 ways work, but no cab mount light, the pedal mounted brake light switch is bad.
Old Mar 11, 2014 | 02:38 PM
Fordcrazy21
Thank you, you've been a great help
Old May 14, 2014 | 08:27 PM
Snowseeker's Avatar
Snowseeker
Noticed my brake lights weren't working tonight. Same deal as Fordcrazy21. Was it the pedal switch for you Fordcrazy?
Old Jul 7, 2014 | 06:57 PM
capndan77's Avatar
capndan77
I'm dealing with a similar problem on F-53 chassis, 2008. Hit brakes, fuse pops. If I only operate 4-ways, no problem. Only happens when I hit brake pedal. Prior to this issue, I spent a couple days with cruise control stopping on its own as though I had hit the brakes but hadn't done so. This cleared up on its own and then the brake issue began. Somehow think these are tied together. Any suggestions?
Old Jul 7, 2014 | 10:37 PM
Snowseeker's Avatar
Snowseeker
My issue turned out to be the multi switch in the steering column. Took it out and then apart, cleaned it, lubed it, and reassembled and worked great again.
Old Jul 8, 2014 | 07:25 AM
capndan77's Avatar
capndan77
Thanks
Thanks, that shouldn't be a big chore and it might be the simple fix I need. Trying to get to the shop with no break lights could be iffy.
Pheadrus
Jan 31, 2026 11:00 PM
F250_
15
Jun 23, 2014 08:59 AM
steelbill58
Jan 25, 2013 08:58 PM
JB_85F150
2004 - 2008 F150
Jun 2, 2011 12:33 PM
noggins71
Jun 11, 2009 09:11 AM
