Coil voltage questions
Old Mar 10, 2014 | 08:52 PM
84espy's Avatar
84espy
I'm in the middle of a few mods on the dent and wanted to start it up today, since it hasn't run for a month. A freshly charged battery, several minutes of cranking and the dent still doesn't run. I will be checking the coil for spark when it's dark, but, I'm curious, the battery shows 12 volts and the coil shows 6.5 volts with the ignition on. Also, I'm thinking I may have deleted a wire, when removing some of the heater harness. Is there supposed to be a wire to the coil when the starter is engaged?
Old Mar 10, 2014 | 08:55 PM
fmc400's Avatar
fmc400
MSEE
"Ignition on" is ambiguous. There is START and RUN. In RUN, the coil voltage should be approximately half the battery voltage. In START, the coil voltage should be equal to the battery voltage. Your numbers look good assuming the key is in RUN for this test. And yes, there should be a wire from the 'I' terminal of the solenoid to the positive terminal of the coil.
Nevermind the exploration with the multimeter yet, check for spark first.
Old Mar 10, 2014 | 08:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
In "run", the power to the coil runs through a resistor wire. The voltage you see is correct.
When the key is in the "start" position, the coil gets it's power from the "I" terminal on the starter solenoid and gets a full 12 volts.
EDIT: fmc beat me, old age is slowing me down .
Old Mar 10, 2014 | 09:09 PM
fmc400's Avatar
fmc400
MSEE
OR, all that time you're taking on that beautiful truck of yours!
Old Mar 10, 2014 | 09:40 PM
84espy's Avatar
84espy
Thanks as always guys. When the engine is running, does the coil voltage stay at 6V?
Old Mar 10, 2014 | 09:48 PM
fmc400's Avatar
fmc400
MSEE
It may climb a little closer to 7 volts because the battery voltage increases as the alternator charges the battery, but yes, more or less.
Old Mar 10, 2014 | 09:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks, fmc.
hotrodjohn71
Jan 18, 2018 05:37 AM
ostrx250
1978 - 1996 Big Bronco
Jul 16, 2013 07:00 PM
Ra_
Electrical Systems/Wiring
Jul 9, 2009 06:51 PM
texcan
Dec 10, 2007 09:53 AM
DrFord
May 10, 2002 11:23 AM
