Need Help With Wiring ID
Old Mar 10, 2014 | 06:26 PM
1972RedNeck's Avatar
1972RedNeck
Can anybody tell me which wires go to/do what and when/if they have power? I have a few figured out from the Chilton's manual and my ford manual doesn't have any schematics.
It plugs into here and runs to the engine.
Old Mar 10, 2014 | 06:31 PM
Chevy_Eater's Avatar
Chevy_Eater
They go to your truck!
Sorry.
You know, I started to write that down when I re-wired mine, but it never got finished.
All I can tell you off hand is the fat yellow wires go from your starter relay hot side to your glow plug relay and they are hot all the time.
Dave S had a breakdown of most of the wires, you might want to search his posts.
Old Mar 10, 2014 | 06:38 PM
Chevy_Eater
Ah, found it, this was helpful when I put the 7.3 into the '85, I had to graft the two harnesses together:
https://www.ford-trucks.com/forums/8...ml#post8098024
In fact, I think I'll stick it in the FAQ.
Old Mar 10, 2014 | 07:00 PM
1972RedNeck
How about the blue?
Old Mar 10, 2014 | 08:40 PM
rufflanding's Avatar
rufflanding
I know that blue wire at least on my 88, I just dealt with that sucker yesterday I had broken it accidentally when changing out my valve cover gasket, It took me hours to find it because it was broken off right next to the connector. I believe it is coming from one side of the 'wait to start light' the other side, at least on my truck, was connected to the ignition terminal on the glow plug relay. Now I'm not positive this is the way things are supposed to be but at least it got things working for me.
Old Mar 10, 2014 | 09:50 PM
Chevy_Eater
That makes sense, well except the hooked up to the ignition terminal part, but the wire coming off the module for the WTS light is blue:
bigfish6025
18
Apr 5, 2015 06:42 PM
Jeff396
Apr 18, 2012 09:03 AM
RodneyH
Jan 3, 2011 02:58 PM
f100guy
Dec 9, 2007 08:46 PM
knapikmichael
Nov 22, 2007 04:39 PM
