Need some quick help with GPR wiring!!
Old Apr 17, 2012 | 10:57 AM
Jeff396's Avatar
Jeff396
Hey all,
I'm in the process of changing my glow plug relay and don't know where the wires connect. The new Napa relay has an I and an S on it where the small wires go. There is a red wire and a purple wire with a red stripe. The old relay doesn't show anything to identify what they were and the manual I got online shows a plug instead of two individual wires. Can anyone help me sort this out?
I'm thinking it doesn't matter which lug the large logs go on. Is that correct?
Thanks,
Jeff
Old Apr 17, 2012 | 12:05 PM
DIYMechanic's Avatar
DIYMechanic
Yeah that is correct and it doesn't really matter which lugs the small wires go on either. One is hot the other is connected to ground by the PCM.
Old Apr 17, 2012 | 12:11 PM
Jeff396's Avatar
Jeff396
Oh, I would have never guessed that. Thanks a bunch!!!
Jeff
Old Apr 17, 2012 | 12:18 PM
DIYMechanic
Yeah basically the two wires just turn on the relay. One has to be hot, the other has to be to ground in order to complete the circuit and make the relay come on. If you want to get really technical there is a right and wrong way to connect it, but the bottom line is that it will work either way.
In case you're the "type A" personality and will lie awake at night worrying that your GPR is connected backwards and is causing a disturbance in the force, here is a picture:
Old Apr 17, 2012 | 12:37 PM
BlueMule's Avatar
BlueMule
Jeff
Which relay did you get from NAPA? GPR109 is the one you should be using. I used a NAPA relay years ago and I don't remember it being labeled that way. The reason I'm asking is because a starter relay looks the same but is grounded through the case and on a GP relay the ground is supplied by the PCM. There's just something about that "I" and "S" that makes me think of a starter relay.
Old Apr 17, 2012 | 12:53 PM
DIYMechanic
If I recall correctly the GPR109 I bought a year or so ago had the "I" and "S" molded into the top of the case by the small terminals.
Old Apr 17, 2012 | 04:21 PM
Jeff396's Avatar
Jeff396
I'm a reformed type "A" personality. I haven't cared in 5 months now....applause!!! I put it in and it worked.....that's all I care about. I don't have the box any more....it's already in the trash and taken off to the dump. Okay, so I'm **** about the garbage.....boooos I got the Napa part number here and it was GPR109 and that's what he gave me.
On a low note the check engine light just came on in my Porsche Boxter S. You think these trucks are expensive to maintain try one of these. It's like the national debt!!!!
Jeff
Old Apr 18, 2012 | 07:01 AM
DIYMechanic
Jeff
Glad to hear it is working. I have the opposite problem, it seems the older I get the closer I am to becoming a type A personality.
And yeah I know what you mean about the Porsche...that's why (okay so that's only one very minor reason why -- other than the fact that I am broke and can't afford one) I don't drive one.
Old Apr 18, 2012 | 08:49 AM
Jeff396's Avatar
Jeff396
Better watch that!!! You might end up in a retirement community with hundreds of "A" type personalities......and that's not pretty!!!
The Porsche's are really quite affordable used. I got an '02 Boxter S which is the HP version five years old with less than 50k miles on it for $21k in 2009. 0-60 in 5.5 seconds with a top speed of around 165 mph. It ain't your mama's Miata that's for sure!!
Jeff
Old Apr 18, 2012 | 09:03 AM
Jeff396's Avatar
Jeff396
Of course it could be the Prozac too
friskyjake
Mar 21, 2017 03:34 PM
pwjackson42
Oct 17, 2015 06:16 AM
Jessef250
Jan 9, 2011 05:06 PM
kilapapipa
21
Feb 11, 2009 07:55 AM
Banshee Ben
Jul 8, 2005 04:29 AM
