99 mountaineer power lock
Old Jul 1, 2003 | 08:32 PM
jcpierce's Avatar
jcpierce
Need to remove driver side power lock button to replace and or clean....any help on how to get it out would be helpful...thanks
Old Jul 1, 2003 | 08:57 PM
Premier's Avatar
Premier
I would unscrew the two screws near the door handle, then remove the door pannel.(this is kinda a pain in the *** but it should pull right off with a little elbow grease) then you should have access th the back of the power lock button and also the power window buttons.
Old Jul 1, 2003 | 09:07 PM
jcpierce's Avatar
jcpierce
Thanks
jcpierce's Avatar
jcpierce
Thanks
Old Jul 1, 2003 | 09:17 PM
Premier's Avatar
Premier
I also forgot to add that when you pull the panel off, be careful not to pull on the wires too hard. And the little push in white plugs(were on mine anyway) that snap into the pannel, I used needle nose pliers to pull them out of the door and snapped them back into the pannel, then pushed the pannel back onto the door. Just trying to make it easier for ya
maagk
Jun 7, 2016 07:17 AM
Papasmithnc
1997 - 2003 F150
Jan 18, 2016 07:04 PM
Mr. Hatt
Feb 15, 2010 03:37 PM
turborich
Jul 25, 2008 10:51 AM
Fentin_Fury
Aerostar
Sep 16, 2003 10:29 AM
