Sponsored by: Real Truck
Need help on front differential
Old Mar 9, 2014 | 12:45 PM
4X4HB's Avatar
4X4HB
I need help to figure out which differential I have in my 2002 F350 superduty 7.3 L truck, I have a knuckle seal and the axle seal on the differential that need to be replaced, and every place I have went to needs to know which axle I have in my truck, so I was hoping someone on here could be kind enough to be able to help me out with what I have.
Here is what the front differential tag has on it.
V2C34 FB
611299-1
I can give vin number too if that would help.
Thanks for any help I can get, I need to get the seals ordered so I can get them in because I have a trip come Thursday and I need the truck.
Old Mar 9, 2014 | 02:00 PM
JOHN2001's Avatar
JOHN2001
That's a hit and miss year. Most likely it's a Dana 60 but could be a Dana 50. My 2001 is a Dana 50 which I just broke the spider gears in . If I recall correctly the ends are the interchangeable where the axles and ring gear etc are different. Dana 50 has a 9" ring gear and the Dana 60 has a 9.75" ring gear. Worse case scenario you can pull the front diff cover and measure the ring gear to be 100% sure. Those are your only 2 options it's up to you to narrow it down between the two. Good luck
Old Mar 9, 2014 | 02:11 PM
4X4HB's Avatar
4X4HB
Thanks for the reply, I just found another number that is 248, some of the stuff on the net I have found says the 248 is a Dana 60 and the ring gear is 9.75, so from what you're saying could be that it is a Dana 60.
I hope this helps someone to be able to help me, I did find the serial number on the sticker that was still on the housing, so I hope if nothing else maybe Ford can help me figure this out.
Thanks again for the reply, it does help.
Old Mar 9, 2014 | 02:16 PM
JOHN2001's Avatar
JOHN2001
If your ring gear measures 9.75" then you undoubtedly have a Dana 60.
EDIT: Here's a good read for you and anyone else who might be curious http://www.fourwheeler.com/how-to/tr...ont-axle-swap/
Old Mar 9, 2014 | 02:26 PM
4X4HB's Avatar
4X4HB
On my searches I found this that littlehusky had said.
Originally Posted by littlehusky
on your door jamb you can tell as well. It will tell you ~3850 (i think) front axle weight rating (D44hd) or 4410lbs for a D50
The hub picture tells it the best though. The 50's hub fills the whole hole. the 44 has a step down and a smaller hub.
Whish on my sticker on the door my front axle says 5200 GVW, so I am assuming that it would probably mean I have a Dana 60, which goes along with the casting numbers I found on the housing of 248.
Old Mar 9, 2014 | 06:52 PM
jesse5's Avatar
jesse5
Dana 60
You Sir have a Dana 60. While you are in there it would be a great time to inspect/replace the axle joints and ball joints since the same parts have to be removed to do the other parts later.
Old Mar 9, 2014 | 10:09 PM
99f350sd's Avatar
99f350sd
2001 and half changed to D60 As far as i remember.
Old Mar 10, 2014 | 03:19 PM
4X4HB's Avatar
4X4HB
Thank you, and you're right, I am planning on changing everything you had on that list.
Baby Boomer
Aug 13, 2018 10:02 PM
speedracer54729
Jun 20, 2008 09:53 AM
amcv8jeep
Sep 24, 2007 01:49 PM
mroidt
May 8, 2003 07:59 PM
nicksort
27
Oct 6, 2002 09:04 PM
