Sponsored by: Auxito
2003 f150 heating/defrost problems
Old Mar 8, 2014 | 08:44 PM
Dan_T's Avatar
Dan_T
I'm having what seems to be a pretty common problem with my vent doors not working correctly.
Max A/C.........blows air out of panel vents, air is not cool or hot
Vent..............blows hot air out of panel vents
PNL/FLR.........blows hot air out of defrost vents
FLOOR...........blows hot air out of defrost vents
FLR/DEF.........blows hot air out of defrost vents
DEF...............blows hot air out of defrost vents
So far I visually checked all the vacuum hoses up to the fire wall. I sprayed carb cleaner on all the vacuum lines and connections to the fire wall. I removed the EATC. I'm getting vacuum to the back of the controller. I have replaced the o rings but I haven't re installed the EATC yet. It got to dark on me so that will have to wait until morning.
Could it still be a vacuum leak up front even though I am getting vacuum to the back of the EATC? When I changed the O-rings they didn't look bad, maybe a little flat but not bad.
Old Mar 8, 2014 | 09:47 PM
steve(ill)'s Avatar
steve(ill)
if you have vacuum, but doors dont position correctly... i think the best guess is the o-rings leaking inside. Hope that fixes the problem !
Old Mar 8, 2014 | 10:27 PM
RedRauder's Avatar
RedRauder
Sounds like you might have bad o-rings, looks like you are on top of the problem
Old Mar 9, 2014 | 11:26 AM
Dan_T's Avatar
Dan_T
The O-rings did the trick. Everything is working how it should. Thanks to all the info I picked up on this great site.
Carpenterw1
Sep 8, 2016 09:39 PM
Aerocook
Aerostar
18
May 18, 2014 10:33 AM
shakebaker69
1997 - 2003 F150
Sep 3, 2013 06:13 PM
rockos3354
Escape & Escape Hybrid
Sep 19, 2010 11:47 PM
acrete
May 30, 2006 08:53 AM
