HELP!! TOW/HAUL LIGHT FLASHING
Old Mar 8, 2014 | 06:15 PM
03powerstrokefl's Avatar
03powerstrokefl
i just replaced an injector last night and after i got down i took it for a test drive and my tranny felt like it slipped then jumped back into gear and did it again. Then i seen my tow/haul light flashing so i stopped and shut off the truck and plugged my programmer in to do a dtc test and it popped some codes so i cleared them. i couldnt go fast at all, it would be at a high rpm. I googled what was happening and i read that the trans temp sensor could be bad so i went to my local store and got it and dropped the pan swapped the sensor out and filter and filled my tranny up with new mercon sp. i dont know what is going on???? it popped some speed sensor codes but they went away and i cant figure it ou. someone help please !!!
Old Mar 8, 2014 | 06:54 PM
steelhead2's Avatar
steelhead2
What were the code numbers?
Old Mar 8, 2014 | 07:06 PM
rdfenn3's Avatar
rdfenn3
I had the same issue but my tranny guage wasn't working. Temp sensor fixed my problem. Did you disconnect batterys? If so I would think the computer prob needs to learn again.
Old Mar 10, 2014 | 07:25 AM
03powerstrokefl
P0730 incorrect gear ratio and it popped some other ones but I cleared those dtcs and never came back but this one pops up every time
Old Mar 10, 2014 | 07:26 AM
03powerstrokefl
I did do that and it did reset but it just doesn't shift right. I feel like it's a sensor doing it. Or why else would the light be flashing
Old Mar 10, 2014 | 08:16 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The light is flashing because the gear ratio is wrong in the transmission. The other codes that were set would be a BIG help in determining what's wrong. I recommend you keep driving until the codes come back. Without the codes all I can tell you is that something is wrong.
Old Mar 10, 2014 | 08:37 PM
03powerstrokefl
Intermediate shaft speed sensor circ p0791 and intermediate shaft speed sensor circ no signal p0793 also it had one about friction element d
Old Mar 10, 2014 | 08:56 PM
Mark Kovalsky
You need to electrically check both the intermediate speed sensor (located on top of the trans, about halfway between the front and back) and the wiring to the sensor.
Old Mar 10, 2014 | 09:12 PM
Unrealo4's Avatar
Unrealo4
When you did your injector work did you disconnect the drivers side battery?
Old Mar 11, 2014 | 03:36 PM
03powerstrokefl
No i didnt disconnect it. why is that have to do with the tranny ?
Old Mar 11, 2014 | 06:37 PM
Mark Kovalsky
Because disconnecting BOTH batteries will clear the Keep Alive Memory for the transmission.
Old Mar 12, 2014 | 04:18 PM
03powerstrokefl
Disconnect them for how long
Old Mar 12, 2014 | 07:44 PM
Mark Kovalsky
Five minutes will do it.
Old Mar 14, 2014 | 06:06 PM
03powerstrokefl
Okay so I did that and it ran good for a couple of days so I decided to hook my edge ht tuner back up. I only run it on economy mode for better mpg. That's when it started doing it again. What could that be?
Old Mar 14, 2014 | 07:28 PM
steelhead2's Avatar
steelhead2
Your edge tuner.
