P1249 Wastegate Fail
Old Mar 8, 2014 | 03:36 PM
St Pete Bumper Man's Avatar
St Pete Bumper Man
Today I have replaced few sensors on my '01 7.3 Excursion 4x4. I get this code P1249 Wastegate Fail Steady State Test. I replaced the exhaust back pressure sensor and the MAP/IAT sensor. I also cleaned out the BPS bracket (completely clogged) and tube. A bicycle brake cable made into a little chimney sweep, worked great! I'm thinking the Wastegate Actuator is stuck or is it the valve in the turbine stuck? How can I tell what is bad? Is this what I need to replace?
Thanks for your help
Old Mar 8, 2014 | 04:07 PM
Stewart_H's Avatar
Stewart_H
Moved to the 7.3L PSD forum.
Stewart
Old Mar 8, 2014 | 07:06 PM
duck fan's Avatar
duck fan
Because racetruck
Are you running any sort of tuner or programmer?
Dave042
20
Feb 12, 2019 02:20 PM
Nolo263
Oct 1, 2015 07:55 AM
chris86924
Mar 30, 2015 05:27 PM
rickdavis81
Oct 13, 2014 08:56 AM
jakemb
Feb 20, 2011 11:30 AM
