new truck
Old Feb 17, 2011 | 07:17 PM
jakemb's Avatar
jakemb
new truck
To me.bought another project and was wondering if anyone can give me info on the codes read today.1996 4x4 crewcab long box manual trans.Truck low on power and runs a bit ruff cold but better hot.
p1271 cylinder 1 high to low often
p1298 idm fault
Contribution test, cyl 1 balance fault.
thanks for any info.
Old Feb 17, 2011 | 07:49 PM
jakemb's Avatar
jakemb
Took a look threw the paperwork and also have code p0470-exhaust pressure sensor fault,I'll try and do a search on here for info.
thanks
Old Feb 20, 2011 | 10:32 AM
jakemb's Avatar
jakemb
I posted but still haven't recieved much feedback.I found some info but not finding much for p0470 and what problems it will cause.I know it is the exhaust pressure sensor fault.I'm just wonder what causes this code and what affects it has on performance.1996 psd manual trans
thanks
Old Feb 20, 2011 | 10:42 AM
fordpride's Avatar
fordpride
P0470 is the exhaust back pressure sensor it controls the EBPV (exhaust back pressure valve on the pass side of the trubo
under the sensor their is a tube that goes to the pass side exhaust manifold the sensor and tube is most likely stoped up. the sensor will not cause the truck to run bad
Old Feb 20, 2011 | 10:46 AM
jakemb's Avatar
jakemb
Thanks you,I just needed to know if this would be something i need to look now or can wait.I'll look at fixing more important items first.
Old Feb 20, 2011 | 11:17 AM
rodneywar's Avatar
rodneywar
it can wait you have a bad number one injector the idm code is more likely a false code i get it all the time and befor ruling out the injector check the pins in the uvch
Old Feb 20, 2011 | 11:30 AM
jakemb's Avatar
jakemb
Thanks,just pulling the valve cover,pretty darn cold out so not sure how far I'll get today.
DRRXR
Oct 30, 2016 01:22 PM
JC155
Sep 13, 2016 10:56 PM
avvidclif
Aug 11, 2016 03:55 PM
Romeo Scorpion
6.7L Power Stroke Diesel
Aug 8, 2012 10:24 PM
01silvergt
Jul 13, 2005 02:08 PM
