6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
p008c code
Old Mar 7, 2014 | 11:03 AM
TruckGuy27's Avatar
TruckGuy27
p008c code
So I have this p008c code up on the scan tool, (no CEL), and a not readiness code (p1000)... I've been reading up on this fuel cooler pump and how some people are trying to release air out of the system, etc.
But I have no coolant or anything leaking. Could simply replacing the fuel filters be the solution? Any help appreciated, THANK YOU.
Old Mar 7, 2014 | 06:26 PM
bubbasz1's Avatar
bubbasz1
I don't think the filters will do anything for you. I believe that code tells you your truck has an open circuit on the fuel cooler pump. Check for loose wires, maybe power at the plug, could just be burned up motor.
LeoH
May 29, 2014 12:09 PM
brainfart
1983 - 2012 Ranger & B-Series
Apr 12, 2006 08:37 PM
waro
Nov 30, 2004 06:24 AM
tatesomero
Mar 15, 2004 07:01 PM
