Rear brake issues..
Old Feb 22, 2016 | 08:41 AM
fifty-two_f1's Avatar
fifty-two_f1
Rear brake issues..
On my 86 f250, the rear brakes don't seem to be grabbing, but in the morning (sometimes) when I step on the brakes the rears will lock up. It'll do that once maybe twice then that's it. Brakes feel stiff again and I don't stop as well. I replaced the master cylinder thinking something was internally wrong because over time the fluid from the rear reservoir would somehow end up in the front brake reservoir and would run out the cap and onto the inner fender. I have not driven it much with the new master so the fluid level seems to be okay in both reservoirs. Could this be a prop valve issue? The brakes have been bled sufficiently, the pedal is hard and not spongy. Fluid does flow freely to the rear when bleeding so I am at a loss for whats really going on? My next plan is to pull the prop valve, take it apart and make sure everything looks good but I don't really want to open the system up (again) unless I have to. What do you guys think?
Old Feb 22, 2016 | 02:22 PM
Franklin2's Avatar
Franklin2
Pull the rear drums and see if you have a leak. Your shoes may be soaked with oil or brake fluid.
FlaHawg
Sep 15, 2013 05:51 PM
fred_79f250
Apr 23, 2012 03:58 PM
Waxhead654
Dec 13, 2010 07:26 PM
Jarniscipus
Aug 25, 2010 02:06 PM
hevnbnd
31
May 7, 2006 10:25 AM
