E4OD PROBLEMS. NEED HELP!
Old Mar 5, 2014 | 05:51 PM
Ben24's Avatar
Ben24
Hi I have a 94 f150 302 4x4 with the e4od. The tranny won't shift into any gear. I move the shifter from park all the way to 1st. And nothing. Just wondering if this is a major problem or if it could be something less extensive like an electrical issue. ALL HELP IS APPECIATED
Old Mar 5, 2014 | 07:11 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you need to make sure the shift linkage is actually shifting down on the side of the trans.maybe the shift cable or bracket down below broke?
Old Mar 5, 2014 | 07:23 PM
Conanski's Avatar
Conanski
And pull the codes.
Old Mar 5, 2014 | 07:28 PM
JWC 3's Avatar
JWC 3
You have checked the fluid level ...?
Old Mar 5, 2014 | 08:59 PM
Toplait's Avatar
Toplait
E4OD Diagnosis Thread - FSB Forums
https://www.ford-trucks.com/forums/2...-the-mlps.html
Old Mar 5, 2014 | 09:10 PM
Ben24's Avatar
Ben24
Originally Posted by Conanski
And pull the codes.
Is there a certain tool I can get that does it? All I have is one that reads the engine codes
Old Mar 5, 2014 | 09:11 PM
Ben24's Avatar
Ben24
And yes I checked and topped off fluid
Old Mar 5, 2014 | 09:12 PM
Ben24's Avatar
Ben24
Thanks I'll look at that tomorrow
Old Mar 6, 2014 | 08:55 AM
subford's Avatar
subford
The code reader that reads engine codes also reads transmission codes.
Are you sure you have an E4OD, most 5.0L had the 4R70W transmission in them.
What is the transmission code on the drivers "B" pillar?
Old Mar 6, 2014 | 02:50 PM
Ben24's Avatar
Ben24
I'm positive it's e4od. I looked at pictures before of what the trans pan looks like and it's definitely what I have. I found out what the problem was. The electrical connection right above the shift linkage came loose. Reconnected it and it works like it did before
pilotadam
Dec 3, 2012 08:07 PM
lurch
1978 - 1996 Big Bronco
Mar 25, 2004 04:09 PM
