AC Not Working?
Old Mar 6, 2014 | 03:04 PM
  #31
Vanet's Avatar
Vanet
The reason you cant mix is because it is illeagal not that they are not compaible. The enviro stuff will actually mix very well with either, works better than both and is cheaper. BUT the feds say dont mix, so if you do its on you. I first did the enviro just so I wouldnt have to drain all the r-12 out of my system. However it worked so good, that I switched all my stuff over to it. I am in AZ and here you might as well not have 134, it just doesnt work well enough.
Old Mar 7, 2014 | 07:05 AM
  #32
10thMountainMechanic's Avatar
I got an update, I feel like a complete retard lol I jumped the low side switch and the compressor works just clicks a little but it might be from not having any oil in it for such a long time but anyway I went to test psi on the low side service port and the damn things already been retrofitted to R134a! I couldnt test at the low side due to my fitting on the guage being messed up but high side was 30psi....so I'm gonna vacuum it and get some r-134a, fill it up and test for leaks.
Old Mar 7, 2014 | 07:58 AM
  #33
Chevy_Eater's Avatar
Chevy_Eater
Hey, you're making progress and some of the work's already been done for you.
Old Mar 7, 2014 | 11:15 AM
  #34
genie2011's Avatar
genie2011
thanks
thank you for the information.
Old Mar 7, 2014 | 08:11 PM
  #35
Macrobb's Avatar
Macrobb
Oh, and R134A and R12 use different oils. Either works fine, but a mixture of both doesn't, apparently.
Usually, though, doesn't the oil come in a separate can?
Old Mar 8, 2014 | 09:08 AM
  #36
mineral oil for R-12 and PAG oil for R-134A I think U can get seperate cans or a premix...not sure though
Old Mar 8, 2014 | 02:07 PM
  #37
Chevy_Eater
Yep, and ester is compatible with both so it's what you do with a conversion that has old parts in case there is residue.
I buy the bottle and pour it in directly. You have to open the system up anyway to change the o-rings.
http://www.ebay.com/itm/TSI-Supercool-Polyol-Ester-Oil-8-oz-E7-/130893226450?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e79d821d2&vxp=mtr
Akzep69
1978 - 1996 Big Bronco
Jun 20, 2015 04:07 PM
joe f350
Nov 1, 2013 09:30 PM
billj6
1983 - 2012 Ranger & B-Series
Jul 23, 2008 06:24 AM
JTHill24
Aerostar
Jun 30, 2006 09:28 AM
javi2001
Aug 23, 2003 08:01 PM
