Sponsored by: Real Truck
BATTERY KEEPER
Old Mar 4, 2014 | 08:22 PM
gene daniels's Avatar
gene daniels
BATTERY KEEPER
Return of The FORD Battery Keeper !
Cleaned n painted right front fender well inside under battery/washer fluid reservoir. This is maintenance at 6 years or less with salt.
Scummed with insect debris, lost lineman’s plier$, one hex key fossilized onto shelf leaving rust streak. Paint’s good but the truck has not gone thru salt or major rainfall periods.
When new painted upper inside well under A/C condenser with 3 coats quality urethane spray paint. No rust on drip surface, rust streak from cable holder hole. Used Rusto clean metal primer brush on and gloss white for this bottom area. Sticks
Cut the reservoir pump cable, solder later, turn reservoir clockwise pull out against upper inside fender toward engine side.
Bottom surface is accessible for electric drill with wire rotary and cup brushes.
https://picasaweb.google.com/1022344...BATTERYKEEPER#
Set a floor fan atop batt area at 83 degrees curing in 5 hours.
Left side next thru an access port after removing grille. Moving fuse box/power steering reservoir is an unknown. Advice ?
BleedMichigan
Apr 9, 2019 05:47 PM
1984 f-250
Paint & Bodywork
Jan 24, 2007 06:16 PM
Fair 96
Paint & Bodywork
Apr 28, 2006 11:12 PM
dan1101
Oct 10, 2004 12:39 AM
