ForSCAN
Old Mar 3, 2014 | 03:40 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thumbs up ForSCAN
I couldn't find any posts in the 6.7 section about this - although there were a couple in the 6.0l section.
Recently my truck had an erroneous airbag light, as well as the buttons on my steering wheel for my command center stopped working, my truck is out of warranty, and I like trying to diagnose these issues my self anyway... I suspected my Clockspring (a common fault on Super Duties), but wanted to check further.
As some of you might know, codes that aren't engine/transmission related aren't accessible through most code readers, as all different brands of vehicles use different codes for airbag/body etc. issues. You can buy code readers that can read some of these codes, but they are both expensive (~$200+), and don't always have the codes for every vehicle.
After some research, I found this:
FORScan Home
Its freeware, that you can download to any Windows based computer, and as long as you can connect your computer to your OBDII port, supports all Ford/Mercury/Lincoln/Mazda models, and can read codes from all modules, as well as do some other diagnostic/monitoring (I actually think that if you had a portable Windows based platform that could run this program it would do anything the Edge CTS can do, plus a lot more).
All you need for it to work is an ELM 327 style connector to your computer, either a USB style connector, or a Bluetooth one. I chose the latter as it will enable me to use the connector with my Android phone and the Torque app if I so chose.
Here were the connectors I ordered:
BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY : Amazon.com : Automotive BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY : Amazon.com : Automotive
Amazon.com : Kinivo BTD-400 Bluetooth 4.0 USB adapter - For Windows 8 / Windows 7 / Vista : Usb Network Adapters : Computers & Accessories Amazon.com : Kinivo BTD-400 Bluetooth 4.0 USB adapter - For Windows 8 / Windows 7 / Vista : Usb Network Adapters : Computers & Accessories
It was a straight forward install/setup process, and I was immediately able to see the codes that were present, both the steering wheel buttons and the airbag light said open circuit (and it was the drivers airbag), which went with my guess of it being the clock spring. I cleared the codes, restarted, and the codes returned, so there is definitely a connection issue, with 99% possibility of it being in the clock spring.
Anyway, just wanted to make sure you were all aware of what I think is a really awesome, and very cheap tool.
Old Mar 3, 2014 | 05:34 PM
rtazz17's Avatar
rtazz17
Cool... I have a autoengenuity with the ford pack scan tool from when I had my 2002 7.3 .. I wonder if that could grab the codes off of my current truck? If it doesnt then I could prolly use that software you referenced with the usb to OBD connector I have for the auto enginuity right?I should go try it.I do have a edge cts.Would the edge be able to get those hidden codes?
Old Mar 3, 2014 | 05:43 PM
720Deere's Avatar
720Deere
Rob, you can update your AE to the latest version but of course there is a cost. If the version you have is pre-2010, it won't work unless you update it.
BigF350.......nice informative post!
Old Mar 3, 2014 | 10:28 PM
BigF350's Avatar
BigF350
FTE Emeritus
You can use the cable that came with it, connect your vehicle to a laptop with FORscan, and read the codes.
Old Mar 7, 2014 | 12:39 AM
n6nfg's Avatar
n6nfg
Have you tried to get any of the DPF PID's to be displayed yet (like the Edge CTS can do)? This would be really excellent, as no one else seems to be able to display the DPF stuff for any reasonable price.
Old Mar 7, 2014 | 10:23 AM
BigF350's Avatar
BigF350
FTE Emeritus
My truck is deleted, so I haven't.
I'll plug it in tomorrow, and see if the PID's are there (even if I can't read them)
Old May 1, 2014 | 04:07 PM
BigF350's Avatar
BigF350
FTE Emeritus
I meant to update this thread. I was able to fix the Instrument Cluster Menu buttons on the steering wheel (which were not working) and an airbag light by using this to diagnose. It was a faulty clock-spring.
Old May 1, 2014 | 04:32 PM
ctubutis's Avatar
ctubutis
FORScan Home
I wonder if I could put together such a system to read everything from my mom's '06 Nissan Altima, that would be cool.
Old May 1, 2014 | 09:17 PM
2addy's Avatar
2addy
Great post BigF350; thanks for sharing. When my '12 got smacked, the windshield wiper pump motor wouldn't work after it was fixed and the body shop couldn't read the code so this would have saved me a lot of grief.
Old Sep 27, 2016 | 11:31 AM
PSM 6.4's Avatar
PSM 6.4
I know this is a old thread but, can you use the AE proline VCI connector with Forscan?
Old Oct 7, 2016 | 08:38 AM
89LX306's Avatar
89LX306
I couldn't get my AE proline connector to work. I ended up ordering this bluetooth adapter off Amazon and it worked fine with forSCAN.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Amicus
Mar 31, 2017 11:53 AM
Fastfwd
Jun 26, 2014 07:06 AM
Treytaw
Apr 19, 2013 06:23 AM
Craze
Jul 12, 2004 02:06 PM
turbo menace
Dec 18, 2001 05:32 PM
