differential fluid
Old Feb 20, 2015 | 01:30 PM
Dakster's Avatar
Dakster
Originally Posted by 17 Oaks
After the first change, you can make the oil last almost forever by gluing a rare earth magnet on the bottom area but out of the way.
The magnets are about the size of a dime only thicker and they are STRONG. This will catch all the fine metal from wear, oil will look new a 100k later
SInce some of us have old computer and drives laying around. Here is a "free" source for a rare earth magnet.
And if you have a bad and old hard drive that spins, they have a couple of rare earth magnets in them. I have one out of a laptop spinning drive on my fridge. (The SSDs won't have them). It is amazing how strong they are, I put it on the fridge and you have to peel it off the edge to remove it and it has a lip on it so you actually can grab it.
One of the things I didn't like about my 2011 with the plastic oil pan and plug was that there was no place to put a magnet - at least for it to work. Also one of the things I don't like about a fumoto - no magnet at the end of the drain plug either.
I usually change over to synthetic diff fluids around 10k miles and find small metal specks in the oil. Then I never mess with it. Usually because I haven't kept a vehicle to over 100k miles in a long time. Never changed tran fluid - especially in these trucks always seems to look perfect. I hate Honda for that - one at 7.5k and then every 15k you are doing a trans flush/fill on their AWD vehicles.
Old Feb 21, 2015 | 09:30 AM
my_crib_too's Avatar
my_crib_too
Originally Posted by ruschejj
Good question. My 2011 had over 200,000 towing miles on it, never touched any diff or trans fluids. Not once. Trans fluid always looked new and it always shifted same except a little chirp going from 4-5.
I don't read much here around changing transfer case, diff, or transmission fluids. Started wondering if it was because the 6.7l is only since 2011 or if FTE members typically don't change them. Is changing these fluids an old habit for some that they continue to do even though fluid quality has improved over the years and this is not necessary with modern fluids. I've not kept my last two trucks long enough to change these fluids, it's just something I was thinking about. I also think owners of 6.7L trucks tend to fluids better than your average car owners. I don't know one person in my circle that changes their own oil, yet many here still crawl under their trucks for oil and fuel filters all the time.
Old Feb 22, 2015 | 12:13 PM
ruschejj's Avatar
ruschejj
Well, I can tell you this. I've never considered messing with the rear diff on my trucks but after reading your question and the mag hytech thread it's got me thinking it would be fun to do. Just for fun though, lol. I still think it would be impossible for the diff and trans to overheat and damage themselves being used in a typical/responsible manner.
Old Feb 22, 2015 | 01:09 PM
17 Oaks's Avatar
17 Oaks
You are correct!
In most axle setups there is room for more oil than the fill plug allows. Those that run lifted rigs have a tendency to have short lived axle sets due to high pinion angles and since the pinion bearing gets its oil from 'splash' the high angle starves it.
But Wait...there is a solution, go buy a 1" brass street elbow (NOT 1" in diameter but length) and install it on your axle, use it to fill with and you give it enough oil to keep from starving and keep it cool to boot and not have to spend hundreds on a new cover....
Old Feb 22, 2015 | 01:22 PM
69cj's Avatar
69cj
You are correct!
As stated before, more oil just takes a little longer to heat up. It won't run any cooler. More oil also takes longer to cool down.
Old Feb 22, 2015 | 01:28 PM
17 Oaks's Avatar
17 Oaks
We can agree to disagree on this...
Bowstring
Aug 2, 2022 07:23 PM
DND58
Sep 25, 2010 09:20 PM
bashby
Jan 17, 2010 08:45 AM
dave3406
Nov 1, 2008 10:21 PM
ac700wildcat
13
Aug 6, 2007 11:42 PM
