differential fluid
Old Mar 2, 2014 | 01:47 PM
Nad's Avatar
Nad
differential fluid
I have a 2011 F350 SRW with 3.55 differential. I'm was going to change the fluid, however, what type do I use? The manual calls for 75-90 with the Dana rear end or 75-140. How do I know which rear end I have? Is there a build sheet with code on the vehicle anywhere?
Old Mar 2, 2014 | 01:51 PM
TRENT310's Avatar
TRENT310
SRW rear axle is going to be the Sterling Heights 10.5" ... I'm reasonably sure the only Dana Rear axles are the DRW models.
Also, the axle code is on the B-pillar sticker as a 2-character code.
Old Mar 2, 2014 | 01:54 PM
720Deere's Avatar
720Deere
Yep, Dana 80 is only in the DRW 350. Everything else is the Visteon Sterling 10.5.
Old Mar 2, 2014 | 02:15 PM
Tom's Avatar
Tom
Just out of curiosity how many miles do you have on it?
Old Mar 2, 2014 | 06:10 PM
Nad's Avatar
Nad
The truck currently has 55K miles on it.
Old Mar 2, 2014 | 06:13 PM
UGA33's Avatar
UGA33
Nothing wrong with doing it to see what it will look like. I did on my 6.0. Dropped it at 50k miles. Looked brand new. If you haven't submerged it in water or have a leak, I would leave it alone.
Old Mar 2, 2014 | 06:46 PM
720Deere's Avatar
720Deere
I swapped the diff oil in my 2006 at 56,000 miles. It wasn't that the oil wasn't up the demands of the bearings, it was the lousy Trac Lock limited slip differential that was picky about the oil. Fresh oil and friction modifier always seemed to tight the trac lock up.
Since these trucks don't have a limited slip with clutches, I'm not in a big hurry to change the diff oil. Who knows, I may do it this Summer at something like 65,000 miles since I have had the oil on the shelf for like 4 years now. I will probably add a Mag-Hytech cover in the process since my rear axle is loaded pretty heavy with the toy hauler.
Old Mar 2, 2014 | 07:24 PM
senix's Avatar
senix
I did my 08 every 60K.
Old Mar 3, 2014 | 12:15 AM
TRENT310's Avatar
TRENT310
I did mine earlier because I got it wet when I ripped off the breather tube by accident with some use/abuse. Then considered an aftermarket diff cover, then realized my diff is plenty cold as it is and doesn't need heatsink fins.
Old Feb 19, 2015 | 08:49 PM
my_crib_too's Avatar
my_crib_too
** old thread warning **
How often does Ford recommend changing differential (front/rear) fluids? Transmission and transfer case fluids?
With engine oil, seems like half the FTE members wait for the light, while the other half have their own schedule that is shorter on miles. Considering the Ford recommendations how often do most here change each of these fluids?
Old Feb 19, 2015 | 08:53 PM
ruschejj's Avatar
ruschejj
Good question. My 2011 had over 200,000 towing miles on it, never touched any diff or trans fluids. Not once. Trans fluid always looked new and it always shifted same except a little chirp going from 4-5.
Old Feb 19, 2015 | 09:13 PM
Desert Don's Avatar
Desert Don
I have come to the conclusion that by doing all this scheduled maintenance on diffs and trannys, that we really are doing the next owner of the vehicle a huge favor!!!!! And they should reward us!
Old Feb 19, 2015 | 09:32 PM
Iowa Ford's Avatar
Iowa Ford
Funny thing is, in my experience with cars and trucks, problems start when you change the tranny fluids at 80K. Either do it early and often or never.
Old Feb 20, 2015 | 05:09 AM
senix's Avatar
senix
100K on the front diff and I do 60K on the rear diff and transfer case.
I think I will probably do the trans at 60K as well.
Old Feb 20, 2015 | 12:58 PM
17 Oaks's Avatar
17 Oaks
After the first change, you can make the oil last almost forever by gluing a rare earth magnet on the bottom area but out of the way.
The magnets are about the size of a dime only thicker and they are STRONG. This will catch all the fine metal from wear, oil will look new a 100k later
