Getting gas but dying
Old Mar 1, 2014 | 05:56 PM
Frdtrckfn's Avatar
Frdtrckfn
My 89 straight six is getting to the engine but doesn't seem like its actually getting in the engine
Old Mar 2, 2014 | 12:33 PM
J_O_E_Y's Avatar
J_O_E_Y
If you are positive the engine is getting fuel I would check the fuel pressure regulator (FPS) for fuel and listen/spray for vacuum leaks. Having a gauge to check pressure would be a bonus. Could also be the IAC motor, bad injector, dirty throttle body or MAF, bad 02 sensor. Lots of possibilities.
Old Mar 2, 2014 | 03:08 PM
Conanski's Avatar
Conanski
The fuel system should be generating 50-60psi at the motor, get yourself a gauge and find out where you stand. If that is within spec pull codes and go from there.
Old Mar 2, 2014 | 03:47 PM
sixpackjack's Avatar
sixpackjack
harbor freight has a nice cheap pressure gauge kit sounds like it could be a fuel pump going bad,but
bvillarreal186
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 24, 2015 08:56 PM
eldoradoman
Bronco II
May 10, 2015 03:30 PM
90fordguyohio
Dec 19, 2010 08:00 AM
gmc28
Nov 18, 2010 08:09 AM
kawa
Oct 24, 2007 06:37 PM
