4x4 problem
Old Mar 4, 2014 | 07:43 PM
Jus2shy's Avatar
Jus2shy
For RAM, there's a center axle disconnect, but that's it. It's an electric solenoid that engages the passenger side half shaft (vs. the older vacuum design). No hub disconnect that I know of, but there are after market manual hub kits and center axle disconnect disablers out there as well.
Old Mar 4, 2014 | 07:51 PM
M1919A2's Avatar
M1919A2
Originally Posted by hschiro
Coming up the mountains here in Ca last night. Snowing and slippery. Put truck in 4x4 light came in saying engaged. Driving very slowly and almost slid off road with two kids and wife in car. Then noticed that there was no front traction happening. Locked hubs manually and all was ok. I think this is a serious problem. If in auto and dash confirms 4x4 engaged then it should be. I am just very lucky to not have seriously hurt my family or someone else. Is this a recall on Fords part I truly think they need to be held accountable if so. Thanks in advance for any info.
Big issue with the Raptor - it doesn't have manual option as the Super Duty's have.
Old Mar 4, 2014 | 08:07 PM
sawtooth's Avatar
sawtooth
by the way, I put my truck in neutral and there's normally no clunk. Seems to just go right in if I do it that way.
Old Mar 5, 2014 | 05:54 PM
boatman33's Avatar
boatman33
been through this issue a few times with my 7.3 trucks. every time it was the hub seals leaking. it would leak the vacuum down and the hubs would not engage. the telltale on the 7.3 is if the defrosters come on when you put it 4wd. (drops the vacuum for the climate controls.) don't know what will happen if the seals go bad with the 6.7 vacuum system.
Enduroman
Jul 25, 2019 06:28 PM
truckfella
Dec 11, 2013 09:12 AM
parkland
6.4L Power Stroke Diesel
Jan 29, 2012 08:59 PM
wetsu1
Feb 16, 2009 01:50 PM
bignorth
Jan 18, 2007 12:21 AM
