Water temperature locations on engine
Old Feb 28, 2014 | 11:55 AM
tractormanbill's Avatar
tractormanbill
tractorman
I have a 302 with 2 bbl. carb and would like to know if there is more than one location on the engine where I can read engine coolant temperature?
I need a dash gage reading & electric fan switch location.
Thanks, Tractorman Bill
Old Feb 28, 2014 | 02:05 PM
xlt4wd90's Avatar
xlt4wd90
Usually the sensor for the gauge (and EEC, if your engine is computer controlled) is located at the water outlet on the intake manifold. This is about the hottest place for the coolant, as it's just leaving the engine after picking up all the heat from the heads.
Old Feb 28, 2014 | 03:01 PM
tractormanbill
tractorman
Temp sensor holes in the engine
Is there another port that I could also install a dash sensor unit?
Might be able to drill and tap one.
Thanks, Bill
Old Mar 1, 2014 | 03:42 AM
xlt4wd90's Avatar
xlt4wd90
I think on most Fords, the gauge sensor is on the intake manifold right before the outlet port. See the little brass looking thing on this 1968 302:
https://plus.google.com/photos/11555...67774490549511
There's usually a boss at that location that provides enough meat in the manifold to support drilling and tapping a hole for a sensor, and usually done at the factory. For the EEC engines, there is a second port for the computer's sensor nearby. Again, there is a boss for that as well. I'm not sure if there are other places where you can drill into a water passage. You can check the intake manifold that you're working with, but I'm almost certain that it will have a tapped hole in the right place.
Old Mar 1, 2014 | 10:02 AM
tractormanbill
tractorman
Thanks and I will check some more.
I need a port for the electric fan switch and a port for the original 6V. dash gauge sending unit unless I try to "T" which I would rather not do.
Thanks,
Tractorman Bill
Old Mar 2, 2014 | 04:29 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Some thermostat housings have a hole that can be used. "T" doesn't work, sensor needs to be in the water flow.
BWD444
Jun 30, 2017 02:35 PM
aking225
Aug 26, 2010 07:58 PM
XLRANGER94
1983 - 2012 Ranger & B-Series
Jan 13, 2010 05:24 PM
joebeeone
1997 - 2003 F150
May 2, 2006 09:10 PM
fordboy_52
Aug 26, 2005 08:34 PM
