Steering Wheel Audio
Old Feb 27, 2014 | 07:26 PM
frittingles's Avatar
frittingles
Hey all, just wondering if anyone has worked out a wiring diagram for the steering wheel audio controls? I am trying to hook up to an aftermarket Sony system.
I have found this picture if it helps...
2002 Ford Explorer Limited
Last edited by frittingles; Feb 27, 2014 at 07:28 PM. Reason: Fixed the picture link
Old Feb 27, 2014 | 09:31 PM
shorod's Avatar
shorod
You don't mention what year you're interested in, but the service manual does often show the resistor values for the steering wheel controls. For example, pasted below is the schematic for the 2002 Explorer.
-Rod
Old Mar 1, 2014 | 03:31 AM
frittingles
Sorry, I did put "2002 Explorer Limited" under the picture, but it obviously wasn't visible enough, so, good guess!!
Thanks very much for replying to my post - I'm sure I'll be able to work out something between these two pictures.
Thanks again.
Old Mar 1, 2014 | 07:49 AM
shorod's Avatar
shorod
So you did, I missed that.
It would appear that if you plan to re-use the factory steering wheel controls you'll need to change some resistors (probably surface mount), re-run some of the traces (unless you re-purpose buttons) and limit the functionality of the aftermarket deck slightly. It does seem like a fun project though.
I think there are also some aftermarket interfaces that will do this for you as well with a little box that translates the OEM current drive to what the Sony deck is expecting for that function. I think the brand is PAC...? Something like Pacific Audio Controllers? If you're not as much interested in the project as you in the functions you might want to look them up.
-Rod
firestroker8706
Dec 5, 2010 11:45 AM
250Texas
Mar 30, 2007 10:50 PM
Finjima
1983 - 2012 Ranger & B-Series
Mar 2, 2006 11:58 AM
