I don't really understand alternators:
Old Feb 28, 2014 | 04:16 PM
Tedster9's Avatar
Tedster9
What's surprising is that the 12 volt system is still around, it's not 1953 anymore and power demands have increased dramatically. But basically, the same battery is still in use today. There was some talk a few years ago of a new 48 volt system but kind of dropped off the radar.
Old Feb 28, 2014 | 05:03 PM
Tom's Avatar
Tom
It's kind of an interesting discussion here. I tend to think the parasitic losses of a dual alternator setup may be minimal, but even a fraction of a percentage adds up over time. Think about it, 150,000 miles of fuel at $4/gal is over $35,000.
If a second alternator reduced efficiency by 0.5% it would cost $175 in fuel over that 150,000 miles. Of course it's nowhere near as simple as that in a real world situation, but small losses can add up to big bucks over time.
Old Feb 28, 2014 | 05:16 PM
ruschejj's Avatar
ruschejj
Thank you all for kicking this thread around. Fun to read, I'm learning some stuff.
Old Mar 5, 2014 | 04:18 PM
perfpower's Avatar
perfpower
Originally Posted by Bobbykjl
My opinion: There is a benefit, whether it's prudent to make a change is another thing. BTW The load on the engine is insignificant (in regards to single or dual).
Advantages:
More available current (if you need it)
Redundant system if one fails (it'll get you home)
Less wear due to working less. The alternator can be viewed the same as your engine; if it has an easy life it has less wear, if it is operating at the top of it's range it has more wear (higher temps, brush/slip ring and bearing wear).
Disadvantages:
An extra part to fail. Even though combined they are working less than a single unit and theoretically can last longer because of this, they are still spinning and wearing in regards to brushes, slip rings and bearings. Not to mention unexpected or premature failure of electronics (regulator and rectifier diodes).
https://www.fleet.ford.com/truckbbas...ml/Q-160R1.pdf
It is offered and is not a difficult modification.
You keep the original 200amp alternator and add a 157 amp alternator. Bolt on the below parts and have Ford program the PCM
Single alternator to dual alternators:
Alternator Assembly:
Primary: 200 amp BC3T-10300-BA
Secondary: 157 amp BC3T-10300-EC
Alternator Belt for dual alternators:
BC3Q-8620-GA
Alternator Fasteners:
W715092-S437: M10 x 92 mm (lower alt bolt) Qty 2
W715094-S437: M10 x 40 mm (upper alt bolt) Qty 2
Secondary Water Pump*:
BC3Q-8501-BB
Wiring Harness:
BC3Z-14305-F
Hi Bobby - I actually purchased everything on the bulletin for the second alternator and we are trying to install it now. Having some trouble installing the new secondary water pump. Does the belt tensioner have to come off for this? Any help is much appreciated.
Old Mar 5, 2014 | 07:06 PM
elee3's Avatar
elee3
My truck came with dual alternators and I'm not sure why. I bought it new off of the lot and it doesn't have any special options that I would think requires a second alternator. I don't have the supplemental heat option. I have speculated that someone ordered it then backed out. Any idea what options warrant the additional one?
Old Mar 5, 2014 | 07:13 PM
720Deere's Avatar
720Deere
For some reason, some dealers order them that way. My brother bought his 2011 off the lot with dual alternators and it was only there a few days before he bought it. I don't think it was a rejected order. The supplemental heat requires either the HD or dual alternator option, but his truck doesn't have the heater either. The only odd option that he has is the plow package.
Old Mar 5, 2014 | 09:21 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
IIRC its a relatively inexpensive option when ordered from the factory, and a bunch of fleets (plow trucks, ambulances etc.) often require the dual alts anyway.
Old Mar 6, 2014 | 09:45 PM
Dakster's Avatar
Dakster
Doesn't the cold affect how things charge and draw power as well? In colder areas it might make sense to always get them. I find that good dealers know what sells and what people are looking for and try to order their stock that way.
There is no option that is needed to order duals. at least on the order sheets I see. Seems like if you sell a lot of trucks to upfitters that the dual alternator setup couldn't hurt. I have the Heavy Duty Alternator in mine. Duals are $380 on a 2014.
What is with having to add a secondary water pump for dual alts? That is a new one for me.
Old Mar 7, 2014 | 12:10 AM
BigF350's Avatar
BigF350
FTE Emeritus
Its just replacing the water pump housing. Part of the housing makes up the mounting bracket for the 2nd alternator. They obviously figured it was cheaper to have 2 pump housings than pay the 10c extra for the additional material for the mounting points to be fitted to every truck.
Old Mar 8, 2014 | 07:48 AM
jfritz_drfritz's Avatar
jfritz_drfritz
Would the 200 amp alternator fit in the spot of the secondary i.e. Can you get 400 amps total??
Old Mar 8, 2014 | 11:41 AM
BigF350's Avatar
BigF350
FTE Emeritus
I suppose in theory, yes. Both the 200 and the 157amp alternator use the same mounting points. I am not sure if there are any clearance issues (i.e. is the 200amp physically larger). I know it used to be.
Old Mar 8, 2014 | 04:21 PM
Dakster's Avatar
Dakster
My theory on two 200 amp alternators is this. In order to run 2 alternators you have to get the ECM reprogrammed. Why would Ford make a 357 Dual Alt. Kit and not a 400 amp?
My fear is that the ECM wouldn't like seeing 2 - 200 Amp alternators. In the old days it really didn't matter, but today, the darn computer knows everything.
Old Mar 17, 2014 | 09:30 PM
  #28
strokin83's Avatar
strokin83
Does anyone know if it is possible to swap the 157 amp for the 200amp? I have a buddy who is shopping for a new Ford and wants a XLT with the center console and the HD alternator. He's having trouble finding a truck with both. I would think it would swap out but I'm not sure.
Old Mar 18, 2014 | 01:28 PM
  #29
BigF350's Avatar
BigF350
FTE Emeritus
I believe its just a bolt in swap.
danorules
2004 - 2008 F150
Sep 14, 2012 01:11 PM
grinnergetter
Sep 1, 2011 10:14 PM
Saleenguy
Feb 14, 2009 12:17 AM
rustyoldford
Electrical Systems/Wiring
Apr 3, 2007 03:52 AM
Mike W
Dec 11, 2002 10:50 AM
