Engine block heater
Old Feb 27, 2014 | 09:52 AM
loksoff's Avatar
loksoff
Engine block heater
I recently purchased a pulsating tank style block heater for my truck. I'm running a 4.9l straight six with a holley 4 bbl and a offy dual plane intake. Currently I have a heated carburetor spacer plate and a heater plate under the intake manifold. I'm wondering where the best place to tie in this block heater would be. I purchased this style because I liked the idea of bein able to start my truck and have my vents blow warm air right away, because it gets cold here in Nebraska. My first instinct was to have the heater output go to the heater core, manifold plate, carburetor plate and then back to the engine, but the more I thought about it the more indecision I had. Let's hear your opinions. I wanna tackle it this weekend.
Old Feb 27, 2014 | 10:16 AM
Harte3's Avatar
Harte3
There is a plug in the block just above and near the front of the starter. I plumb into the block there for the heater inlet and the outlet plumbs into the heater hose returning to the water pump. The heater is mounted on the firewall. I use the Kat's 1000w circulating tank heater. Nebraska winters gave me my introduction to block heaters.
Old Feb 27, 2014 | 02:35 PM
loksoff's Avatar
loksoff
Are you speaking of one of the freezer plugs? So the fluid leaves the heater unit and goes up to the core and then back down towards the water pump?
Old Feb 27, 2014 | 07:07 PM
Harte3's Avatar
Harte3
No, it's not a freeze plug. It is a block drain hole with a threaded plug in it.
Old Feb 28, 2014 | 12:49 PM
loksoff's Avatar
loksoff
Cool I appreciate your input. Whereabouts in brasky are/ were you?
Old Feb 28, 2014 | 06:15 PM
Harte3's Avatar
Harte3
Auburn for 4 years and another 4 in the Bridgeport, Broadwater and Bayard areas.
Old Jul 24, 2014 | 04:34 AM
hermancm's Avatar
hermancm
It went below zero 64 times up here last winter! Im becoming a heat guru for my atv and the dent lately!
David Fehir
Jan 22, 2016 05:25 PM
jeffbradbury7
Feb 3, 2013 05:59 PM
FarmLaw
Jan 10, 2004 02:27 PM
dlpinkc
Jan 8, 2004 10:28 PM
icebreaker88
Feb 18, 2003 02:28 AM
