Drive Shaft Question
Old Jan 19, 2002 | 04:58 PM
dj9124's Avatar
dj9124
I have a 53F100 that I am putting a 302 with a C6 tranny and have a stock Dana rear end with a 3.92 ratio. The truck did not have a motor, tranny or driveshaft when I bought it. I have access to a driveshaft out of a 1987 F150 and was wondering if anyone knows if this shaft would fit. I know it may have to be shortened but I am mainly concerned about the yokes. It will fit on the tranny side because I am useing the C6 tranny out of the F150 but will it fit the rear end side? Thanks for any help someone may be able to give me.
Dave
Old Jan 19, 2002 | 09:03 PM
Franklin2's Avatar
Franklin2
They make u-joints that will adapt things over. Take the driveshaft with the u-joint you have to your local Napa store. Get them to look up and get the u-joint for the original rear yoke on the old truck. If they have the bearing cup diameters, and the width, they should have a u-joint that will fit. That's how I did mine on my 53. I also installed a slip yoke out of a early bronco into my 80 4x4 by using a u-joint that adapted it over.
Old Jan 19, 2002 | 09:21 PM
cobraguy's Avatar
cobraguy
I just got two "conversion" U joints at my local drive shaft shop. I found out that ALL Ford F-1 - F100 48-66 had all the same u joints originally. The cap dia is 1.063"-1.064" and a 3 7/32" yolk width. These numbers plus the measurments for the driveshaft end and you'll be in business. The u joints were cheaper at the driveshaft shop then at the parts store, and the parts store had to special order them.Good luck, Rich.
Old Jan 19, 2002 | 11:53 PM
dj9124's Avatar
dj9124
Thanks a million Franklin2 and Cobraguy, that helps me greatly!
Dave
Old Jan 20, 2002 | 08:59 AM
economan's Avatar
economan
if ya gt a wreckin yard that will letcha walk around just take a measuring tape with ya and checkout every driveshaft ya come across that looks close.....actually some yards have a pile of shafts ya can paw thru. i just completed a s/b chevy conversion in my 58 merc 100 & ended up that a l/b reg cab s-15 shaft was exactly right(including the $10 price tag), just hadta buy the adapter universal for one end.....lot more cheaper & y'know the balance should be there in the driveshaft if it is factory made.
Mikie !
Old Jan 22, 2002 | 02:24 PM
markd's Avatar
markd
A '76 Granada shaft was just right lengthwise for a 302/AOD in a '50 F1. It had the correct joint at the rear and used the same yoke as the AOD. I don't know about C6 splines, but there is probably a yoke that will work without trick joints. I would stay away from trick joints, you can't always find them in the middle of nowhere in the middle of the night........
Old Jan 22, 2002 | 03:36 PM
Franklin2's Avatar
Franklin2
The ones I needed where in stock at napa. They acted like it was no big deal.
Old Jan 22, 2002 | 04:42 PM
mtflat's Avatar
mtflat
preppypyro
Jun 7, 2011 01:35 PM
dave91gt
Jul 23, 2009 03:39 PM
f100guy
Oct 28, 2004 05:26 PM
Dave 69_88 F Series
Jan 8, 2003 12:13 AM
