Wow that's s nice Lil adventure there Mr Oz, glad everything held up, you sure out that c6 through a torture test huh? That prolly wasn't a Thang for the ol 6.9 tho
IDI stuff is pretty thin on the ground down here and if you can find it is ridiculously expensive. I will probably rebuild the c6 myself. Has anyone got an idea of good rebuild kits on ebay? Everyone says their kits are heavy duty but I am skeptical.
Hi oz. I recently had mine rebuilt, it turned out to be s gas trans. To replace clutches, new wider bands, shift kit the valve body and mod the torque converter to lower the stall, and buy a large cooler was 2 grand nz. On top of that I removed and reinstalled it myself, and filled it up with new oil.
it looks like a decent kit.
but i think i would go with this one instead:
http://www.ebay.com/itm/Ford-C6-1976-96-4x4-Master-Rebuild-Kit-C-6-Truck-Automatic-Transmission-Overhaul/201428364999?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33421%26meid%3D33cf053f79b3411b8d9cc4e2a289c9f6%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D220540680436
