About had it
Old Feb 25, 2014 | 09:02 PM
Crossbones5's Avatar
Crossbones5
About had it
I have a 93 f250 with the 460 that starts fast and runs strong. The problem is once it starts, even if I only run it for a few seconds, it sometimes will not start back up. Last week I started it up, jumped out to let it warm up and it died within a couple seconds. No big deal I thought as I got back in, but it would not restart and I had a strong gas smell coming into the cab.
also, when its cold it always starts right up, but when its been driven a bit and I try to start it up again it takes about 10 seconds before it will start and it sounds like the battery is dying while I am turning it over even though its a brand new battery. This also gives me a strong fuel smell. The starter is less than a year old. I replaced my fuel regulator thinking that might help (what a pain that was to change) but it didnt do any good. I replaced my plugs and wires and still no luck. I would love to drive my truck more but I cant trust it to get me home. any ideas??
Old Feb 25, 2014 | 09:14 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Do you have any check engine lights coming on?
Have you checked your fuel pressure? Also check it when the problem comes up (right when it stalls).
How about spark when the issue comes up?
When you start it and sit in the truck and stay off the throttle does the RPM fluxuate?
Trav
Old Feb 25, 2014 | 09:57 PM
Crossbones5
No check engine lights, have not checked the fuel pressure.
Old Feb 25, 2014 | 10:24 PM
Redneckfordf2502002
I would check the fuel pressure as to me it sounds like a fuel problem. I bet most people will say the same.
Trav
Old Feb 26, 2014 | 12:05 AM
zspeed130's Avatar
zspeed130
Just something to check. I had a similar problem but not as serious plague my dd all fall into winter. After replacing the starter, solenoid and some other stuff due to my own fulty diagnosis it died in the autozone parking lot. After a couple hrs and weird symptoms trying to start I saw a glowing main ground wire. My only issues was trying to restart when warm. Check your connections. Should take 30 minutes and will rule it out.
Z
Old Feb 26, 2014 | 12:09 AM
timbersteel's Avatar
timbersteel
Trav
That or a failing ICM. If it always starts when cold and after it runs a bit it won't restart, that points me to that or a failing PIP/stator in the distributor. Just for grins, take a hair dryer and warm it up before starting it, when it had sat for an extended time and you know it will start. If it doesn't, I think you found the problem. Also coil could be suspect. Try the same heat trick on the coil and dizzy. See what that gives you.
Old Feb 26, 2014 | 05:25 AM
Bob Gervais's Avatar
Bob Gervais
Another thing to try:
When it won't start, hold the accelerator pedal to the floor while cranking and see if it'll start, just like you would with a flooded carbed engine.
Old Feb 26, 2014 | 07:23 AM
dixie460's Avatar
dixie460
Pull the plugs and check for spark after it dies. Bet you won't find any, or if you do it'll be weak.
Timbart1
Mar 10, 2019 02:01 PM
1982fordf100
Nov 18, 2012 08:22 PM
kennn
Oct 30, 2007 11:00 AM
Dutch123
1978 - 1996 Big Bronco
Oct 3, 2005 07:27 AM
Dave88F250
13
Aug 9, 2005 09:59 PM
