6.2L V8 Discuss the 6.2L V8
Listen....what the hay is that noise?
Old 03-03-2014, 03:54 PM
JimRay's Avatar
JimRay
JimRay is offline
Ok, I've heard this a couple of times and I gotta ask. 2014 SD 6.2L gas with the key just inserted into the ignition switch (not turned either direction), I hear a high pitched hum/vibration coming from somewhere under/near the engine. Almost sounds like a fuel pump running dry. Again, not the fuel pump as I cam hear it if I rotate the key.
Maybe a relay coil? Sounds for 3 to 4 minutes and stops and doesn't do it every time.
Thoughts?
Old 03-03-2014, 05:18 PM
saratoga2011's Avatar
saratoga2011
saratoga2011 is online now
My $$ says stepper motor cycling the throttle plate to learn/set its zero position.
Old 03-03-2014, 07:33 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
I hear it also and have no clue
Old 03-04-2014, 12:25 AM
onlydjmac's Avatar
onlydjmac
onlydjmac is offline
I read a post a few weeks ago about a noise with truck off after hitting the brakes and thread said it was a vaccuum pump for the brake system.
Old 03-08-2014, 10:28 PM
RZAR's Avatar
RZAR
RZAR is offline
Its the fuel pump. Basically the fuel runs for a second to prime/build up pressure in the system before you start.
Old 03-17-2014, 08:12 AM
troverman's Avatar
troverman
troverman is offline
Its not the fuel pump. I have wondered about this noise as well. First of all, its coming from under the hood! Plus, the fuel pump prime only runs for a few seconds, not 5 minutes. It usually happens to me if I put the key on to the first position (ignition off) so I can run the radio with the doors open. There is a high-pitched but quiet hum coming from under the hood, maybe on the driver's side. It will last for 5 minutes or so, maybe more. I haven't really, really tried to figure it out, but it baffles me. These trucks are not diesel, so I doubt they have a vacuum pump for brakes. I'm just surprised whatever is running needs to run when the ignition position is not selected.
Old 06-11-2014, 05:40 PM
-brent's Avatar
-brent
-brent is offline
same here, still wondering...
longrange1971
6.7L Power Stroke Diesel
12-08-2017 12:09 AM
cornking
Aerostar
08-16-2013 09:36 AM
midnight1967
05-19-2010 08:38 PM
ac91725
13
03-07-2008 10:35 AM
truckeetom
08-29-2005 12:39 AM
Quick Reply: Listen....what the hay is that noise?
