noise when i turn key on?
Hi i have this higher piched sound coming from what i think is a fuel pump on the frame rail under the drivers side, i dont remember hearing the pump before but now it makes like a high pinched noise almost like it is clogged or something? any help would be great.
Maybe you could get someone to turn the key while you get under the truck. Get close to it so you can verify that it is the pump making that noise. Does the truck start and are you able to drive it and notice any loss of power. I dont think the pump should make that noise if it is it could be bad... more guys will chime in and help
LOL, you too?? good grief, seems to be going around!!!
Refer to
Fuel Pump Alternatives? - Ford Truck Enthusiasts Forums
and
https://www.ford-trucks.com/forums/9...mp-squeal.html
Refer to
and
seems a good reference for fuel pump information is here......
https://www.ford-trucks.com/forums/9...-srt-10-a.html
