6.7 making humming noise when turned off! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 12-07-2017, 01:49 PM
longrange1971
longrange1971 is offline
longrange1971 is starting off with a positive reputation.
Hello all,
Recently (past couple months) I have noticed that the truck makes a humming noise shortly after turning off the ignition. It almost sounds to me like a pump of some sorts thatís trying to prime itself. It seems to be lasting for over a minute and lasting longer as time goes on. Does anyone know what this could be. Definitely coming from engine compartment.
Thanks
Old 12-07-2017, 01:53 PM
Just Strokin
Just Strokin is offline
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
It might be the DEF pump sucking the DEF out of the line. This is one of the sounds heard when you shut off the truck.
Have you searched the forum? There are some threads about various engine compartment sounds. I don't worry about the sounds now days as long as they are not coming from the truck the next time i go to drive it. lol
Old 12-07-2017, 02:41 PM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
F250_Super_4X4 is gaining momentum as a positive member of FTE.F250_Super_4X4 is gaining momentum as a positive member of FTE.
You may be hearing vacuum bleeding off also
Old 12-07-2017, 02:51 PM
camminich's Avatar
camminich
camminich is offline
camminich is starting off with a positive reputation.
Is this with key out the ignition, and for a few seconds, or minutes? I know mine, and other 6.7s I have heard all have their clicks and hums on shut down. And just depending on how far I traveled and how hot the engine is seems to factor how many noises it makes. And that said, none sound out of the ordinary or mechanically bad.
I do notice the sounds are less if I allow the truck to sit in P for about 45 seconds before turning it off, usually then just the DEF pump, and something else that clicks under the hood. Never longer than 20 seconds though.
Old 12-07-2017, 03:21 PM
F250_Super_4X4
The click under the hood is typically your EGR valve losing vacuum
Old 12-07-2017, 03:39 PM
NDE
NDE is offline
NDE is starting off with a positive reputation.
Depending on your year it is most likely the wastegate at the turbo. a search will have many post on it. Dealers used to replace but now say it is nothing to be concerned about.
Old 12-07-2017, 06:25 PM
kper05's Avatar
kper05
kper05 is online now
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
It's the waste gate control valve. It sounds like a muffled mini 12v air compressor. Mine will start buzzing 30 seconds after shutdown and while the engine is idling. It's loud enough now I can sometimes hear it at idle outside of the cab and started doing this about 14 months ago. It didn't do this for over 70,000 miles but it's now considered "normal." I'm planning to ask about it again when my truck is at the dealer next week for other issues to see if I get a different answer. The TSB was 13-10-7.
Old 12-07-2017, 10:04 PM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
DeeDubz is starting off with a positive reputation.
most likely waste gate control valve. Mines been doing it for over a year. You can replace the harness / solenoid to the waste gate to get rid of the noise but it doesn't not damaging your truck.
Old 12-07-2017, 11:20 PM
UP_There's Avatar
UP_There
UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
Mine makes a slight noise every single time after I shut it off, for about 15 seconds, then it stops.
Old 12-08-2017, 12:09 AM
falconetti
falconetti is offline
falconetti is starting off with a positive reputation.
turbo spins for a bit after its shut off.
wrxin
1999 to 2016 Super Duty
09-01-2017 11:23 PM
jethrodean
04-02-2017 06:17 AM
AK_SuperDuty
2017+ Super Duty
02-03-2017 04:07 PM
eddieniner
1997-2006 Expedition & Navigator
05-14-2016 11:00 AM
Marauder_Pilot
04-23-2016 01:26 PM
Quick Reply: 6.7 making humming noise when turned off!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
