tranny swap
Old Feb 24, 2014 | 12:54 PM
batmanbrky's Avatar
batmanbrky
tranny swap
will a 1997 FORD F150 6 CYLINDER 4X4 5 SPEED manual TRANSMISSION bolt in to a 93 302 that had a 3 speed auto??????????
Old Feb 24, 2014 | 01:34 PM
BiGGreen350's Avatar
BiGGreen350
no those are two completely different animals
Old Feb 24, 2014 | 01:42 PM
85e150's Avatar
85e150
Different animals, but the bell housing pattern is the same, so it will bolt up.
However, unless the '93 is a 4x4, you are not going to be able to use the 4x4 trans without changing it to a 4x2 model, is it will be made to bolt to a transfer case, not attach to a drive shaft.
All other auto to stick issues will apply as well.
Are you just looking for OD? An AOD would probably be a bolt in.
Old Feb 24, 2014 | 02:05 PM
batmanbrky's Avatar
batmanbrky
thanks im converting to 4x4 so il have a transfer case on it i just wanted to make sure that the newer transmision would be a bolt up to my block.
Old Feb 24, 2014 | 03:25 PM
BiGGreen350
really, i didnt think they kept using the zf5 in the heritage f150s
i apologize op my info was wrong
Old Feb 24, 2014 | 03:56 PM
Bierisch's Avatar
Bierisch
If it is the 10th Gen F-series it isn't.(I don't think) I am pretty sure it would be the M5OD-R2.
Old Feb 24, 2014 | 04:08 PM
BiGGreen350
well he said 97 150 so thats definitely the 10th gen, still has same bellhousing though??
Old Feb 24, 2014 | 05:02 PM
cjben's Avatar
cjben
I didn't think the modular motors and the older push rod engines had the same bellhousing pattern.....
Old Feb 24, 2014 | 05:11 PM
BiGGreen350
i agree, as stated in my first post on this thread, i thought the old push rod motors and the modular motors were two completely different animals........
Old Feb 24, 2014 | 09:07 PM
Bierisch's Avatar
Bierisch
It's not modular it's the Canadian Essex V6 4.2L OHV engine. And the 4.2L's hat the same pattern as the 4.9L. I believe.
Old Feb 24, 2014 | 09:58 PM
85e150's Avatar
85e150
List of Ford bellhousing patterns - Wikipedia, the free encyclopedia
Thousands of bell patterns, drives many to Chevy.....
Old Feb 24, 2014 | 10:49 PM
Bierisch's Avatar
Bierisch
LOL
Even more refined:
Old Feb 25, 2014 | 08:29 AM
batmanbrky's Avatar
batmanbrky
how much of a pain is it going to be to swap it to manual or would it be worth it to just keep it an automatic
Old Feb 25, 2014 | 08:48 AM
Bierisch's Avatar
Bierisch
After you round up all if the parts the install can be completed in no more than a weekend. I've never swapped to a manual from an automatic, but swapped a m5 to a zf5 and it only took like 1.5 hours. So I wouldnt think it'd take too long.
TL;DR A weekend.
Old Feb 25, 2014 | 11:50 AM
BiGGreen350
its defintiely worth switching to a manual, i am soon to convert my 97 350 to a 5speed. but i bought a whole truck to get EVERYTHING from for the swap. there are tons of small parts that will nickle and dime your budget if you dont have a truckt o grab everything out of, also make sure its the right bodystyle truck, there are tons out there.
not saying you have to have a parts truck, but it is no doubt the easiest way
FordOwnerJoey
Sep 4, 2013 02:31 PM
JayzDaddy
Jan 29, 2013 10:07 AM
cnuke
Oct 21, 2012 09:40 AM
slmann
1983 - 2012 Ranger & B-Series
18
Jul 28, 2005 07:49 AM
duback66
Aug 11, 2004 12:48 AM
