05 died
Old Feb 24, 2014 | 11:54 AM
ballbandit's Avatar
ballbandit
05 died
i got a 05 6.0 with 217k miles. driving down the road and truck died and wouldnt restart. did some checking and no icp pressure and duty cycle on ipr goes wide open. thought it was the stc fitting so i pulled it apart. well fitting was good so since i had a new pump with one piece fitting laying around i put it in with new ipr. put it back together and still no icp pressure and ipr goes wide open. the low pressure comes up on dash while cranking. guess i'll pull valve covers next to check pipes. anybody got any ideas if im missing something? thanks. it does have 3 glow plug codes one being the relay. i dont think that would have anything to do with it though.
Old Feb 24, 2014 | 12:11 PM
jswartz84's Avatar
jswartz84
Sounds like you are on the right path.
Old Feb 24, 2014 | 12:24 PM
9228.bobcat's Avatar
9228.bobcat
Did you try to unplug the icp and crank it?
Old Feb 24, 2014 | 01:27 PM
ballbandit's Avatar
ballbandit
I tried unplugging the icp first thing.
Old Feb 24, 2014 | 01:51 PM
9228.bobcat
Pressurize it and see where the leak is would be my next step.
Old Feb 24, 2014 | 01:55 PM
ballbandit's Avatar
ballbandit
Old Feb 24, 2014 | 02:01 PM
ballbandit's Avatar
ballbandit
I will pressure test tonight.
Old Feb 25, 2014 | 02:17 PM
ballbandit's Avatar
ballbandit
Believe I found problem. The little cir clip and oring in top of #7 injector is m.i.a. guess its in the oil pan by now. Got to finish putting back together tonight. Wonder how often that happens?
Old Feb 25, 2014 | 04:50 PM
matty169's Avatar
matty169
Do the updated stand pipes and dummy plugs while your in there.unless done already.
Old Feb 25, 2014 | 07:58 PM
ballbandit's Avatar
ballbandit
I did do the updates. Luckily I had some.
Old Feb 26, 2014 | 12:10 AM
9228.bobcat
I had one do that. Half the clip was gone along with half the oring. I thought maybe previous owner may have done it being a little rough putting the oil rail back on or something. Who knows. Fixed it ran good. Glad you found your problem.
Old Feb 26, 2014 | 09:02 AM
kbeen's Avatar
kbeen
Thanks for the post. some good information.
schlepprock250
Mar 22, 2016 02:14 PM
jeffy17
Jun 8, 2014 10:55 PM
FTAJ
Mar 31, 2013 03:39 AM
FSeybert
Nov 30, 2011 07:05 PM
waterboy
Jul 17, 2006 04:43 PM
