Sponsored by: Real Truck
Critters in the engine bay
Old Feb 23, 2014 | 06:37 PM
r___r's Avatar
r___r
I can understand critters trying to get warm at night, but, they're chewing on stuff.
In the past in my wife's Accord, I had to replace the overflow coolant reservoir and washer fluid bottle because they chewed a few different holes in them.
We have a pest control company that comes by every month, and, had set out rat & mouse traps around the property.
I'm thinking of getting the store-bought rat & mouse bait, and sticking in the engine bay with double-sided tape.
What do you folks use to rid them and keep them out of the engine bay?
Any ideas appreciated, thanks
Old Feb 23, 2014 | 06:40 PM
dramirez163's Avatar
dramirez163
was recently told by my mechanic about Honda rodent tape. 26 bucks a roll
Old Feb 23, 2014 | 07:16 PM
Sevenlevel's Avatar
Sevenlevel
Wow, I haven't seen this problem myself. I did use to live surrounded by fields on all sides and we had lots of field mice and rats, but they never invaded our vehicles. our two cats loved to jack them though. My first thought jumps to a sacrificial item.. such as a man made box of bait/habitat that they would prefer over climbing your tires. Or, more cats. get more cats. lots of cats. really pissed off mean cats. starved even. GL man.
Old Feb 23, 2014 | 08:35 PM
96fordsix's Avatar
96fordsix
If your local Honda dealer can't find the part number for the rodent tape I can get the number. work in a Honda m/c shop. I have subscribed to this thread
Steve
Old Feb 23, 2014 | 09:47 PM
spdblos944's Avatar
spdblos944
Trailering
I recently experienced the same problem after moving to southern Arizona. I now leave the hood open about four inches and leave a shop light on in the engine bay. The critters seem to be staying away, as it is no longer a warm, dark spot. This remedy was from some of the locals.
Old Feb 25, 2014 | 12:13 AM
r___r's Avatar
r___r
My house is on a 2.5 acre lot in the country and all the critters that come with country-living.
spdblos944, I'll have to give the light a try and see how that works. Thanks
Steve
Hey dramirez and Steve, I have now found the tape online and am now searching for feedback info from people who have used it. Thanks guys
Sevenlevel, the cat idea is a good one, but, I have 3 dogs that go after everything that they are aware of, including neighbor cats. Not sure if that is an option, yet. Thanks for your input
Old Feb 25, 2014 | 12:18 AM
r___r's Avatar
r___r
Anyone else out there use other means to repel the animals from the engine bay?
Thanks
Old Feb 25, 2014 | 01:50 AM
Tedster9's Avatar
Tedster9
Some people say they get good results with moth *****, others say those smelly dryer sheets. Vermin can do real damage, chewing on wire harness and things leading to expensive repair.
Old Feb 25, 2014 | 05:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
I use dryer sheets on my antiques, but you have to replace them often. They stop repelling vermin after 30 days or so.
Old Feb 25, 2014 | 06:33 AM
02TB250's Avatar
02TB250
When you say critters... do you actually know what they are? Depending on where you are snaptraps and/or just relocating or modifying where your truck is parked might fix it.
Old Feb 25, 2014 | 06:35 AM
redford's Avatar
redford
Sticky traps work well also.
Although, PETA says they are among the cruelest methods of trapping a mouse, which I consider a very good endorsement.
Glue Traps: Pans of Pain | Cruel Wildlife Trapping | Cruel Wildlife Control | The Issues | PETA
Old Feb 25, 2014 | 07:34 AM
1amante's Avatar
1amante
I read that if you put Essence of Peppermint oil on cotton ***** and put them in you engine compartment it will keep the mice and rats out. They cannot tolerate the peppermint smell. I put it in my tractor engine compartment, no mice.
Marty
Old Feb 25, 2014 | 08:13 AM
Snowseeker's Avatar
Snowseeker
I set up a pail of antifreeze with a plastic PVC pipe running from the ground to the top of the pail at a slight angle (pvc pipe is around 8' long) with an elbow on the end facing down into the pail. I put peanut butter on the edge of the elbow where they can't quite reach, they slip on the plastic elbow and into the pail they go, over and over again.
Old Feb 26, 2014 | 09:08 PM
r___r's Avatar
r___r
Moth *****, drier sheets, snaptraps, sticky traps, peppermint, peanut butter & anti-freeze.
Lots of good ideas to try. I'm trying drier sheets, now, and I'll try some of the others, as well.
I don't know what is getting in the engine bay, but, since it was several field mice that I caught in the garage with snaptraps when they were getting to my wife's Honda, that is what I suspect is getting in my truck. If I was to relocate my truck, it will still be parked along the edge of the driveway and the pasture.
In the past, I have used a product called Repels-All along the property line to keep the skunks out. It seemed to work well, but I haven't used it for a while, since the dogs are doing a good job. I think I'll go back to spraying again, as well. See if it works on mice.
Thanks guys for all the responses.
Reps to ya,
Old Feb 26, 2014 | 09:35 PM
Bigpipes 35's Avatar
Bigpipes 35
In early fall I put boxes of mice poisen all around our property, I dump a couple of boxes in the wood pile and under anything I can in the yard. Under sheds and everywhere else I can find. The dead ones start showing up a few days later in the yard. To date I havent had any in the house or any of my out buildings since I started doing this..
