1950 Ford F1 pickup with automatic transmission? Fordomatic?
Hey guys, I recently purchased a 1950 F1 with what appears to be an original factory automatic transmission...
Was an automatic transmission offered in 1950 in a pickup?
If so any ideas on production totals?
I will try and get some pics posted..
Thanks in advanced
Thanks in advanced
Comfortable cruise speed is more determined by final gear ratio and tire diameter. That transmission will be a straight through gearing, one in, one out.
Figure out what the rear end ratio is. Possibly a tag thereon.
You need about a 3.50 axle ratio to be comfortable cruising 60 m.p.h.
The steering column looks stock, the steering wheel is stock, and someone added the transmission shifter collar from an early 50s car. What I can see from your pictures make it look like a nice installation. Even if the transmission needs work you can still get parts. Lots of hot rodders pull these out so you might be able to find a good used one cheap if you keep your eyes open.
The Ford-o-matic transmissions came in both air cooled and liquid cooled versions. Air cooled works well behind a flathead.
Curated Content Editor
06-10-2019 09:19 AM
reamer
05-15-2017 08:10 AM
wallster
27
06-01-2013 10:55 AM
Wayne Waldrep
09-21-2012 09:19 PM
