Hi Guys, I need help. I have HOURS invested searching online with no answer.
I have an 2003 E450 7.3L stripped chassis Van. I need a tranny replacement. My E450 van has Tranny mounted E-Brake Questions:
***can an E-350, F350 F450 4R100 tranny work?
***Can I simply unbolt the E-brake drum and remove tail-shaft of 4x2 4r100 and swap them? or does the output shafts need to be replaced?
***Also, can I use a 4x4 4R100 tranny and swap the E-brake drum assembly onto it without Output shaft change?
