Sponsored by: Real Truck
nav headunit ??
Old Feb 22, 2014 | 07:00 PM
oldkountryboy's Avatar
oldkountryboy
nav headunit ??
hey guys i have a 2005 F250 it has the stock head unit in it and i want to upgrade to an oem unit that has nav
will the nav units from 2006 and newer fit and plug and play in my 05 ?
Old Feb 22, 2014 | 07:41 PM
Yahiko's Avatar
Yahiko
You might want to ask here.
Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics - Ford Truck Enthusiasts Forums
I really can't say it the swap will work or not.
Your going to have to add the antenna. If you have the steering wheel controls
then they should work. I know that my 2006 has the VSS signal in the headunit
factory plug.
one thing to do is look up a diagram of the audio system for both years and
see if they match up in the pin assignments in the plugs. If they do then you
might be ok.
Let me know if I can help.
Sean
Old Feb 23, 2014 | 08:16 AM
sammy77's Avatar
sammy77
Nothing is plug and play for your '05 cause the factory Navigation wasn't offered till '08. Aftermarket would be a much cheaper and better option for you, by giving you a lot more features. It will also save you a ton of headaches.
Old Feb 23, 2014 | 09:29 AM
jdadamsjr's Avatar
jdadamsjr
My guess is that only those that have not used the factory nav want it
If I were given the factory nav FREE I wouldn't do it now that I know how bad the mft is !!
We had nav in our 2012 f250 and it was passable, but got MFT on both 2013's and we stopped using it after a week of fighting with it...
Both now have Garmin's or tablets in them when we need nav...
Save your money and your headaches go aftermarket!
(oh, and I'm not slamming just ford's - IMHO, no mfg's nav are up to the aftermarket standards ! - the aftermarket HAS to offer more to be competitive - and I've tried a few mfg's, including Audi and GM's !)
Old Feb 23, 2014 | 06:02 PM
Yahiko's Avatar
Yahiko
Garmin or an Alpine.
The only way I will go now.
Pioneer SUCKS big chunks. between the missing NAV dat and the wrong turn onto an off
ramp. (Yes it told me to go the wrong way onto an off ramp. I did not) New unit had 3 year old
map data on a new unit and they wanted me to pay for the update. It also keeps
restting the play list on the iPhone and then with you want to use the voice command function you
have to wait for it to build the database each time you plug the phone in and you can use it without
having the phone plugged in. Pioneer AVIC-z130-BT. Biggest pile of crap I have ever used.
Sean
Old Feb 23, 2014 | 07:25 PM
dscabra's Avatar
dscabra
Sean
I've looked at Ford NAV head units, but don't think I can easily make them work in my 07. I've been looking at Clarion's new unit -- any thoughts on their stuff?
Old Feb 24, 2014 | 01:21 AM
Yahiko's Avatar
Yahiko
I made a mistake above when I said Alpine. I should of said Kenwood.
One of the things I did after my big mistake with the Pioneer.
I got it at the place I normally go and they said it was SO GOOD (BS is
my answer to that) I found out the Kenwood uses the Garmin GPS
engine. With all the GPS unites I have used I like the Garmin the best.
On other units I really can't say.
Right now I run the standalone Garmin and don't trust the Pioneer for anything.
Sean
Old Feb 24, 2014 | 09:36 AM
oldkountryboy
Thanks guys
Looks like I will just use the clarion I already have
Just wished that they were the same size as the opening so the install looked cleaner
Thanks again guys
toyboxgang
Feb 26, 2011 11:24 AM
bkridel
Aug 5, 2010 06:33 AM
foxcoupe
19
May 25, 2010 01:39 PM
Mr.Watson
Jun 28, 2008 08:52 AM
hotroddsl
Mar 5, 2007 11:36 AM
