Transmission question
Old Feb 22, 2014 | 03:56 PM
Blue Oval 105's Avatar
Blue Oval 105
Have a 95 bronco with a 351. Parked for two months. Got in it today took off and trannys slippin and then shifting hard. But my real question is the overdrive light on the shifter keeps flashing "off". Its a steady flash. Any ideas about the flashing light?
Old Feb 22, 2014 | 04:04 PM
Blue Oval 105
Also the speedo has quit working. It too worked fine when parked. Could it be related?
Old Feb 22, 2014 | 04:50 PM
danr1's Avatar
danr1
Check the fuses? sounds like a blown fuse.
Old Feb 22, 2014 | 05:41 PM
Conanski's Avatar
Conanski
Check fuses and pull codes, this trans is 100% computer controlled.
Old Feb 22, 2014 | 07:41 PM
derek5ocomet's Avatar
derek5ocomet
Speedometer runs off the speed sensor in the rear end as does the ABS. May be a related problem with the trans.
Old Feb 22, 2014 | 07:54 PM
Bob Gervais's Avatar
Bob Gervais
Check fuses 8 and 18. If your dome lights aren't working, it'll be fuse 8.
blueoval65
May 3, 2020 02:03 PM
jesse24spd
13
Mar 29, 2015 12:01 PM
IDI guy
19
Mar 2, 2014 05:11 PM
tps93ranger
Apr 8, 2013 02:21 PM
ctruf1504x4
Apr 26, 2012 08:50 PM
