6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Going to DPF off
Old Feb 22, 2014 | 03:07 PM
KR250's Avatar
KR250
Going to DPF off
I have been running my truck with the stock exhaust, and on Monday I am having the Flo Pro installed. My question is, H&S wants you to install the DPF delete program before you remove the exhaust. If I were removing the exhaust myself this would not be a problem, but I am going to have to run the install in the parking lot of the service shop and then leave it with them. When they work it in they will have to start the motor(now tuned for DPF delete, but with the DPF still installed) an pull it into the garage to work on it. Is this going to cause a problem, is it no big deal, or should I wait and tune it after the exhaust goes on?
Thx for the advice.
Old Feb 22, 2014 | 04:43 PM
bubbasz1's Avatar
bubbasz1
Go ahead and tune it before they do the exhaust, otherwise it will throw codes, probably go into limp mode.
Old Feb 22, 2014 | 09:16 PM
9228.bobcat's Avatar
9228.bobcat
Yup. Wont hurt a thing to tune it first driving that short.
Old Feb 22, 2014 | 09:23 PM
KR250's Avatar
KR250
Right on... Thx for the info!
Old Feb 24, 2014 | 05:29 PM
KR250's Avatar
KR250
I had the DPF and Cat deleted today with a Flo Pro down Pipe back 5" exhaust with muffler, and I installed the HD tune on the Mini Max and set it to street(225).
I have to say, the truck sounds and runs 100x better. You can feel the throttle response right off the bat, with out the old sluggish delay- it just gets up and goes. I haven't run the trans learn runs yet, and I haven't even opened it up yet, but you can feel the power that is there just driving it around town. I need to get out of the typical rush hour schedule to to try to open it up, but living in the city makes this tough. It is still shifting a little hard, but I assume(and hope) this will iron itself out as the transmission gets used to the new power. I also noticed my EGT's dropped about 100-200 degrees on average just driving around town- a nice surprise.
I don't really plan on running it hard, but so far I am very happy with the Flo Pro and Mini Max combo. I will be curious to see what the MPG difference will be, but I am expecting 1-2 MPG, and would be thrilled with 2-3!
Old Feb 24, 2014 | 06:27 PM
Movingsolution's Avatar
Movingsolution
I'm sure you will notice a mileage increase without that stupid DPF on there - I did!
Although it is hard to keep my foot off the throttle now...
Old Feb 24, 2014 | 06:34 PM
9228.bobcat
You will be alot happier now. As stated before its hard to keep your foot out of it now. So the mileage will be hard to tell until you put an egg under the pedal.lol
Old Feb 24, 2014 | 07:51 PM
KR250's Avatar
KR250
WOW....I just did the trans learn runs with the Street tuning(I didn't even try the 300). The tires wanted to spin from 0-30MPH and then pulls straight to 80 in seconds. The nice thing was the oil temp, trans temp and EGT's didn't budge after the run. They went right back to normal. I did start to defuel on the Boost which I have set at 35, but that was plenty of power for me. Very satisfied with this mod combo.
Old Feb 24, 2014 | 08:13 PM
bubbasz1's Avatar
bubbasz1
Just remember, you play, your gonna have to pay, keep a cool head, this is no Mustang, it's a 7,000 truck that you just unleashed.
Old Feb 24, 2014 | 09:44 PM
KR250's Avatar
KR250
I hear you...the only reason I opened it up was to do the trans learn function. I ran it briefly on the stock tune, which is around 50hp, and with the exhaust it was plenty for what I was looking for. I just have to find the best tune for my driving that gives me the best MPG. I am going uder the assumption that the more aggressive tunes provide the best MPG, which is why I have it tuned to the HD tunes.
Thx for all of the advice over the last several weeks. This site was key for my learning curve about this truck!
Old Mar 1, 2014 | 06:27 AM
youngone0916's Avatar
youngone0916
Hey KR, I appreciate the reports back on your changes/results. Really helps me feel justification for spending the $$ lol. I'll be looking for this setup soon.
Old Mar 1, 2014 | 08:44 AM
bubbasz1's Avatar
bubbasz1
Too late now but I never did the trans learn thing, it learned all by itself after a couple of days. Sure makes for a lot happier truck.
Old Mar 1, 2014 | 07:31 PM
Mud Doc's Avatar
Mud Doc
KR250,
Have had the Mini now for over 70000miles, it is a good mod.
Curious tho--you said EGTs dropped, how were you monitoring them before the Mini?
Joe
Old Mar 1, 2014 | 09:12 PM
KR250's Avatar
KR250
Originally Posted by Mud Doc
KR250,
Joe
I was not monitoring them before the mini max, but I ran the mini max with the DPF and Cat on for a couple f weeks before deleting the DPF and Cat and installing the Flo Pro. My comparison was before and after the DPF and Cat delete.
ILMathewsPro
Nov 16, 2012 08:54 PM
Jamie Arceneaux
Sep 29, 2012 07:26 AM
Brooks Rowell
Jun 15, 2010 12:22 AM
Pittsburgh-05HD
Feb 2, 2005 06:59 AM
