help please
Old Feb 23, 2014 | 11:26 AM
  #31
npccpartsman's Avatar
npccpartsman
Originally Posted by brandon.edwards
Ficm repair wins. I'm gonna do the exchange, what did u guys have them program into ur ficm? Stock ford, or php tuning.
I recommend the Atlas 40 unless you're towing very heavy on stock exhaust, then I'd recommend the economy. If you're running gearhead SCT tunes he likes the economy FICM tune to build on also.
Old Feb 23, 2014 | 11:29 AM
  #32
brandon.edwards's Avatar
brandon.edwards
Is there anything wrong with just goin with stock ford tuning? I'm happy with the way my truck runs now. I an runnin canned sct tunes. And am happy with it.
Old Feb 23, 2014 | 11:32 AM
  #33
npccpartsman
No, but the Atlas 40 will give you better throttle response and some maybe improved mileage.
Old Feb 23, 2014 | 11:38 AM
  #34
brandon.edwards
Is the atlas 40 ok to run on stock injectors? I have it studded and deleted.
Old Feb 23, 2014 | 11:50 AM
  #35
npccpartsman
There are LOTS of folks here running the Atlas 40 on stock injectors and SCT tuning. It's perfectly safe.
Old Feb 23, 2014 | 12:37 PM
  #36
mhoefer's Avatar
mhoefer
You will like the atlas 40. What weight do you tow and do you have EGT that you can monitor? Sounds like a winning combination to me. I only run the at last 40 and I can tell the difference from stock. Much better throttle response and acceleration seems a bit fast, mileage has not gone down winter city, and in the fall, highway seemed up a bit, maybe only 1 mpg, but up all the same. I drive pretty hard.
Old Feb 23, 2014 | 06:09 PM
  #37
Yahiko's Avatar
Yahiko
Ed from ficm repair? I found a heavy duty 58v reman on ebay for 350. Is that trustworthy?
Need a reason to avoid 58 Volt.
But if you want to make a new smoker...
Sean
Old Feb 28, 2014 | 04:55 PM
  #38
brandon.edwards
What if my flp is only 11.5
Old Feb 28, 2014 | 06:20 PM
  #39
78fordman's Avatar
78fordman
What is your bat voltage idling? When did you get the 11.5 reading, was it with 2 min of startup?
Sent from my leash using IB AutoGroup
cookingguy
Dec 6, 2015 12:20 PM
Rob Snider
Nov 22, 2015 07:06 PM
RKCORPS25
Nov 1, 2013 09:34 AM
ConvertedFord
Oct 17, 2012 07:44 PM
tgtrotter
Mar 19, 2012 11:36 AM
