Transmission question
Old Feb 21, 2014 | 08:01 PM
shadetree1980's Avatar
shadetree1980
Hi guys, I got another question I need help answering. How can you tell which transmission you have by the VIN #? And also, is there a difference between the 4r75w and the 4r75e transmissions? Thanks again for any and all help!!
Old Feb 22, 2014 | 06:28 AM
projectSHO89's Avatar
projectSHO89
The transmission type is not encoded in the VIN.
The difference is the gear ratio.
Old Feb 22, 2014 | 06:44 AM
meborder's Avatar
meborder
Go Here
and click on the vehicle tab at the top
then enter in your VIN
then on the right, at the top, it will display the primary features your vehicle came with. there is a down arrow key you can click and it will show you everything your vehicle did and did not come with.
FWIW, my 2006 says it came with 4R75E
Old Feb 22, 2014 | 06:57 AM
shadetree1980
Found it. Thank you for the link!!
Old Feb 22, 2014 | 10:58 AM
alloro's Avatar
alloro
This is true, but the VIN can be used to pull up a build sheet for the vehicle, and that will have the tranny type on it.
Old Feb 22, 2014 | 12:03 PM
shadetree1980
Could I use a 4r75w to replace a 4r75e or are they not compatible with the PCM?
Old Feb 22, 2014 | 05:05 PM
projectSHO89
Correct, but only if the vehicle is new enough for data to still be available. The OP gave no indication as to how old his truck might be.
Old Feb 22, 2014 | 06:07 PM
shadetree1980
Its a 2005 Expedition. I ran the VIN and it said that mine has the 4r75E. I can get a good deal on a 4r75W, I just don't know if they are interchangeable.
Old Feb 22, 2014 | 09:32 PM
alloro's Avatar
alloro
If my information is correct, the only difference is that the 4R75E has a turbine (input)shaft speed sensor and the 4r75W does not. If that is true then you cannot use the 4r75W in place of the 4r75E because your truck needs the sensor.
Old Feb 22, 2014 | 09:46 PM
shadetree1980
I'll have to see what kinda deal i can work out for a 4r75E then. Thanks again for your help!
ever22
Nov 9, 2016 04:02 PM
mr big
General Automotive Discussion
Mar 29, 2005 06:12 PM
asigalet
Jun 2, 2004 08:23 AM
eman1217
May 15, 2004 10:15 AM
grandaddy's66
Jan 25, 2004 08:07 AM
