Flow master
This is one of those questions that will elicit responses that will start with "you can but a better muffler would be....insert the brand the respondent has...because of" Many on here run MBRP systems and go with that muffler. I have used magna flow before but I prefer an Aero Turbine.
I see it's your first post so welcome. What size exhaust are you running. While flow master sells full kits that are 4", most of their single mufflers are 3"
I have a Flo Pro and I can't really recommended it, due to drone at 50 MPH.
Not sure what you are trying to discuss (3 1/2" or 3"). If you review the flow master site, the majority of the mufflers offered for our trucks are designed on a 3" inlet and outlet. I asked the question because the OP does not say if he is running a stock system or maybe already has 4" or even 5" pipes and is looking into flow master over what the OP might already have.
I ran magna flow and flow master on other trucks and I went with aero turbine because 1, better material and construction 2, less restrictive and 3, I find the sound produced from the AT to be better than FM or MF JMHO.
I am very happy with my Magnaflow with the 3.5" down pipe and 4" the rest of the way back. Nice sound but not loud, but I am an old f--t.
Re
My truck is stock, and was just looking to put either or, and wondering which would be better for the truck
A stock truck will have a 3" down pipe into 3 1/2" from the down pipe back. The argument of "better" for the truck is a rough one as the forums are full of opinions. If you are looking to move a little more air, go with a 4" from the turbo back. If you are looking to make it louder, remove the current muffler and go with a straight pipe. Some keep the stock down pipe and then run a 4" back. I would argue that a large portion of the muffler debate comes down to personal preference.
If you are looking for a complete system, flowmaster has them, MBRP has them as well as other manufactures. My only advice is, if you are going to do it don't do what I did and purchase individual sections of tubing as it ended up costing me much more than just buying the whole system the first time. I ran a "Frankenstein" system for years that consisted of a 3" down pipe into 3.5" pipe to a 4" muffler then 4" from there. When I finally got around to doing it right I only needed a 4" down tube and the first 6 feet or so of 4" tubing and those individual parts cost me more than buying a complete 4" system.
I plan on going with this Turbo back MagnaFlow. Magnaflow 4" Turbo-Back Aluminized Pro Series Exhaust System 18979
I have BRUTAL drone at 1600 to 1900rpm with the BTM muffler and from the research I have done the MagnaFlow is the quietest.
If the drone is still there I'll slap one of these Drone killers in. I just can' take it any longer!
FTE Resonator 4" Stainless Steel - Resonators / Mufflers
When I bought the truck it had a stock down pipe to a 4" magnaflow and 4" the rest of the way exiting before the rear tire. It sounded good at wot with a nice deep note and while normal driving it was quite. I'm still a younger guy so I ditched that set up for a ss straight pipe turbo back. I liked how the exhaust exited before the rear tire so I kept it that way.
