interchangable parts?
Old Feb 20, 2014 | 04:24 PM
OkieLEO's Avatar
OkieLEO
I am fairly new to this thread but have been doing a lot of reading and searching and gettting quite a bit of conflicting information. I am wanting to see if we cant get a list going of interchangable parts, specifically what I am wanting is stuff like bolt patterns, doors, door panels, mirrors, bumpers, grill guards, grills, lights, etc.... with little to no modification. all help would be greatly appreciated.
Old Feb 21, 2014 | 09:44 AM
WarX's Avatar
WarX
The only one I know is the grille, you can get the 05 one and it fits.
Im not sure but the nice square F250 back bumper also fits.
Old Feb 21, 2014 | 10:05 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Everything from a 99-07 truck swaps to our X's with damn near 100% comparability
Rear doors are different
Rear bumpers from 99-14 are 100% swap. 08+ bumpers look awesome
99-04 trucks have same grille/bumper up front as X
05-07 truck bumper/grill bolt right up...just make sure to replace both at once
You can do a hybrid 05+ grill with 99-04 bumper. Need to cut the 05 grill down
05-07 coil suspension for front is 100% bolt on with Dana 60 axle. Just make sure you get all the parts off the donor truck
05-07 truck axles are 4" wider than 99-04 axles
99-14 bolt patterns are same. The lugnut thread pitch went from coarse to find around 2002. You can use ANY 99-14 rim on your rig. Just have to use 2" spacers on 05+ rims
05+ headlights fit your X with a little cutting of the substructure, use a 9008 bulb vice your current 9007 bulb
There's more. On phone and hand hurts from pecking
Old Feb 21, 2014 | 10:44 AM
OkieLEO's Avatar
OkieLEO
Thanks guys. Thats the info I am wanting.
TYLAS- no rush necessary but when you are at home and have a free bit can you post up the rest you know if its not already.
Reps will be sent. Thanks
Old Feb 21, 2014 | 11:58 AM
Money-Pit's Avatar
Money-Pit
2008 and newer Ford OEM mirrors are interchangable....with a little wiring work and fabrication.
<iframe width="560" height="315" src="//www.youtube.com/embed/2ozhzTOWsTI?list=UUmDIGJLkGRF9xJKdGofKN-w" frameborder="0" allowfullscreen></iframe>
Old Feb 21, 2014 | 08:02 PM
OkieLEO's Avatar
OkieLEO
Thats high speed man I like it.
Old Feb 22, 2014 | 01:09 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
99-14 seats all interchange with each other. depending on year you might have to re-wire a few things. but they bolt up
99-14 mirrors all interchange 100%. see quote below
08+ front door interior panels bolt up with a tiny bit of fabrication...2-3 screws. they rub the dash a tiny bit when door is closed
steering wheels from 99-07 are interchangeable with...as well as the 97-08 F-150, 98-06 Expy/Navi...well a lot of Ford models. So it's easy to find a cheapy nice replacement.
08+ center console or jump seat drops right in there between your front seats perfectly
02+ consoles have deeper cup holders. 99-01 cup holders are affectionally referred to as drink ejectors. 100% swap
05-07 dash cupholders are 100% swap as well...but they don't really flow that well with the 99-04 dash
should be zero wiring if you have a 2002+
you can buy $10 adapter from round to square plugs...or you can just re-wire. it's easy either way
if you want running lights in the mirrors, you can run a wire to the mirror for that. probably the "hardest" part of installing 08+ mirrors IMO
and you only need to snip that locating pin on the 08+ OEM mirrors. Otherwise it's a 100% bolt-on
Old Feb 22, 2014 | 01:30 AM
Psyclopse's Avatar
Psyclopse
I'd like to point out something about the '99 trucks-
There is an early 99 and a late 99- the cutoff month is march, if I remember.
On the early 99, the front axle housing, track bar and track bar bracket are different. In addition to the axle housing being different, the hub/spindle assembly and brake rotors are different- and more expensive. That's why many of us early 99 guys convert to later outer axle stuff.
The early 99 F-250's do have the tall rear blocks though...
Old Feb 22, 2014 | 01:37 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
did not know that. I knew the E99 7.3 motors had different turbo's...interesting to read the other stuff
so lesson learned is stay with 2000+ stuff when mix n' matching for your Excursion
SDElwood
Jan 27, 2011 09:32 AM
nagetech
Aug 23, 2010 10:40 AM
mudracin74
Jun 14, 2007 11:57 PM
jesse460
Jan 7, 2005 09:06 PM
kengarchow
Dec 30, 2004 12:39 PM
