I have a 78' F-150 with a 72' 460. I just recently installed a gauge to replace my dummy light and i never had my light come on. Im not sure what my pressure should be at but when my engine is cold it runs right below 50, as it warms up it drops to 25, when im sitting still it drops to around 6 and sits around 12+ when just cruisein. Is that normal or what should it be at?
that sounds kind of low to me but still high enough not to worry about it if that makes any sense. mine is 60 when cold and 45 when warm. but ive also had 400s with less that 5 pounds at idle. as long as its not rattling or overheating then you have sufficient oil pressure. and its not droping on a regular basis
You know 460's are funny in that way..I have two trucks an F-250 and a f-350 both have the High and Low gauge and a 460 engine. I found they both run the same about 1/2 inch above the low mark. I will say this: One time I put 10-30 in the f-350 and it dropped it to nothing..Now I run 20-50 and I have good oil pressure. Hope this helps..
The engine is loose. Alot of bearing clearance. It will live as long as you don't wind it way upstairs alot. Below 3000 rpm, it should last a long time. My 460 has 180,000 miles on it and it still runs strong. 60lbs cold, idle hot = 10 cruising = 25. It doesn't knock, it just has alot of clearance in the bearings. You can try 20W50 to get the pressure up some. I believe the Chilton's manual says 35 to 45 @ 2000rpm is what is recommended.
voltsnxs: What year trucks do you have? Some time in the late 80's, Ford changed to an "idiot light guage". There is a real gauge in the dash, but just an oil pressure switch on the engine. A resistor makes the gauge read an intermediate value when the pressure is OK.
The pressure switches used on idiot lights and 87 and up gauges will turn off the light or send the gauge to midrange with as little as 4 lbs of oil pressure. Loose engines can survive that low as long as they are not abused with rpm or heavily load.
Precisely why I rebuilt my engine at 135,000 miles. The oil "gauge" showed good pressure, but the oil pump was on it's way south, providing a whole 25 PSI during higher RPM runs up steep Idaho grades, towing, in the heat of the summer. I installed a "real" gauge, which identified the problem.
