WTF Is this thing?
Old Feb 19, 2014 | 11:34 PM
Coastie410's Avatar
Coastie410
WTF Is this thing?
OK I have a 77 F100 ranger xlt 2wd with a 351M. on the passenger fender just to the rear of the starter solenoid is a thing that looks like a relay of some sort.Has a fuse on it. Its not the horn relay. What is this thing and what does it do?
Old Feb 19, 2014 | 11:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Sounds like something that's been added by a previous owner. I don't know of anything that's "factory" that matches that description.
Post a picture if you can.
Old Feb 19, 2014 | 11:59 PM
rockittsled's Avatar
rockittsled
And also the colors of the wires to the relay
Old Feb 20, 2014 | 12:10 AM
HIO Silver's Avatar
HIO Silver
Trace the wires and find out what it is connected to. Prolly an add-on but now would be a good time to find out rather than when attempting to put out the fire it caused.
Knowhattamean?
Old Feb 20, 2014 | 05:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Does your truck have dual batteries? If so, there's a dual battery relay in this approx. location that has a wire feeding from it that contains a glass fuse.
Look on the cover of the relay for an ID number, post what it is.
Old Feb 20, 2014 | 07:29 AM
Dave145's Avatar
Dave145
Or post a pic of it. That always helps.
Old Feb 21, 2014 | 11:51 AM
Coastie410's Avatar
Coastie410
image upload no compression
Old Feb 22, 2014 | 05:09 PM
Coastie410's Avatar
Coastie410
Bueller, bueller? So anyone know what it is and what wires go to it so I can remove it if possible. Also what's the other one all the way to the right?
Old Feb 22, 2014 | 05:27 PM
gatorfor88's Avatar
gatorfor88
Dont overthink things. When in doubt disconnect it and see what dont work any more.
Old Feb 24, 2014 | 08:20 PM
Coastie410's Avatar
Coastie410
Yeah last time I did that the ICM sheit the bed. So anyone else know what these things are?
Old Feb 24, 2014 | 08:29 PM
John R. Thomas's Avatar
John R. Thomas
That might be a headlight relay. It was a common Delco part back in the days
of 6 volts and generators. The switch would trip the relay sending 6 volts off of the
regulator directly to the seal beams. I could be wrong.
I installed one on our 40 Buick. On idle, the seal beams would dim This kept them
bright at all times.
Old Feb 24, 2014 | 09:49 PM
big native's Avatar
big native
Just an idea- maybe a proto-type Flux Capacitor? It will not actually move you through time, but it does give the very real feeling, of driving a 37 year old pick up....
Old Feb 25, 2014 | 04:40 AM
Ordnance's Avatar
Ordnance
I'd be concerned with the orange fused wire just sitting on your fenderwell. looks like an awesome short. No idea what your mystery part is though. Looks like it's just looped around to itself. if anything, pull the glass fuse on it and see what doesn't work. Shouldn't burn anything up, as that would be no different then it blowing.
Old Mar 5, 2014 | 05:42 PM
Coastie410's Avatar
Coastie410
I chased the wires coming from this thing and it goes into the dash and is connected to nothing. Truck is being rebuilt and I have no idea what the PO has done to this thing. So any help? When I turn the key to right before start that thing clicks like a relay
Old Mar 5, 2014 | 05:46 PM
fmc400's Avatar
fmc400
MSEE
No one here is going to be able to tell you what some custom (now partially removed) piece of equipment was intended for. The only person who can do that is the PO. The crimp terminals and fuse holder (not rated for underhood use by the way) clearly exclude it from anything factory.
