1989 5.8 sensor list
Old Feb 18, 2014 | 10:30 PM
zspeed130's Avatar
zspeed130
1989 f250. 5.8, C6. Looking for a list of virtually every sensor and switch etc. related to drive ability I can find. I have dug through parts online and can dig through th manual.
I have, PVC,egr, map, crank, tps, speed sensor, tranny speed sensor (I have a c6 so don't know if I have this one) , temperature, oil pressure, intake manifold temp. Fuel pressure regulator, ignition coil. Ecu of course.
What am I missing?
Thanks for the help
Old Feb 18, 2014 | 11:02 PM
timbersteel's Avatar
timbersteel
Not to sound blunt....but why? And what is the project? This forum covers many years of trucks and various engines/combinations.
Old Feb 18, 2014 | 11:09 PM
zspeed130's Avatar
zspeed130
Apologies. Meant to include that info. This is a nice older truck and I am hoping to wait 1-2 years before having a truck payment for a fast growing lawn care/snow business, having some issues and gonna change the maf and clean he egr tomorrow.
This truck rarely gives me a problem and suits my needs well for now. I just hate having an issue in the middle of a work day or night. It's not that I cannot afford a truck payment, I just don't want to commit to one yet. Also I like having something that has been rung out by so many users. I can normally fix his truck within 6-24 hrs in almost any scenario and I like that. I also think it looks like a real truck as opposed to being shrouded in pretty trim and plastic!
Z
Old Feb 19, 2014 | 07:38 AM
rla2005's Avatar
rla2005
You do not have a MAF, unless someone did a MAF upgrade.
Before you start swapping in parts I highly suggest you start by checking for codes.
Warm up the engine then do this: Fuel Injection Technical Library » How To Run a Self-Test
Run the Key On Engine Off (KOEO) tests and Continuous Memory (CM aka historical) code display. List the codes you received, by number, and when they were displayed.
Or purchase a code reader such as the Innova/Equus 3145
Old Feb 19, 2014 | 08:03 AM
subford's Avatar
subford
PVC - not a sensor but a valve.
EGR - not a sensor but a valve, it does have the EVP sensor on top of it.
MAP - you do have this one as noted above.
Crank - This one is also called the PIP sensor or pick-up sensor, it is inside the distributor.
TPS - mounted on the bottom of the throttle body shaft.
Speed Sensor - mounted on the C6 transmission, sometimes call the VSS.
tranny speed sensor - you do not have this one
temperature - Called the ECT (Engine Coolant Temperature) sensor.
oil pressure - near the oil filter, this is not a sensor, it is a sender for the gauge on the dash cluster.
intake manifold temp - ACT (Air Charge Temperature) sensor located drivers side of the lower intake manifold.
Fuel pressure regulator - not a sensor, a spring loaded vacuum controled valve, returns fuel to the fuel tanks.
ignition coil - not a sensor, an induction coil with a high voltage secondary coil.
Ecu - Called the ECM or EEC Computer, located in the drivers kick panel.
HEGO - Heated Exhaust Gas Oxygen sensor located in the exhaust system.
Old Feb 19, 2014 | 09:12 AM
zspeed130's Avatar
zspeed130
Thank for the info. I'm gonna pull codes today. I'm running rich and also running. Weak/stuttering around cruising speed. Several parts places including napa and rock auto list an maf. It seems to match a small box on the passenger side firewall. What am I looking at there?
Z
Old Feb 19, 2014 | 09:23 AM
Conanski's Avatar
Conanski
The box on the passenger side firewall is the MAP sensor. You also have a seperate temp sender for the dash gauge just in front of the #5 injector. As mentioned pull codes don't just start changing parts randomly, if you're gonna buy anything up front make it an Equus/Innova 3145 code reader..
INNOVA 3145 Ford Digital Code Reader : Amazon.com : Automotive INNOVA 3145 Ford Digital Code Reader : Amazon.com : Automotive
MaxOut
Jul 25, 2023 10:13 AM
schism1861
2004 - 2008 F150
Nov 22, 2020 03:36 PM
Taylor815
17
May 19, 2017 09:32 PM
JMC302
23
Jul 28, 2010 12:36 PM
kanepjk
Bronco II
27
Dec 17, 2006 08:23 AM
